DT Swiss ARC 1650 Wheels Opinions
Does anyone ride the DT Swiss ARC 1650 wheels/know anything about them? I believe they are built specially for BMC (stock on the Timemachine). How do they compare to other wheelsets on the market (Zipp, Flo, Hed, etc.)? Can’t find much on them–probably cause they are not sold separately. Any thoughts appreciated!
https://www.bmc-switzerland.com/intl_en/timemachine-01-disc-one.html
Probably just a downgraded hub (350?) and maybe spokes from the ones you could buy. Looks like the older style rim which was either 17mm or 18mm internal. The newer ones are 20 I think.
I emailed DTSwiss a question about those wheels and this is what they replied. Wheels came stock on my 2020 BMC TimeMachine 01 DISC ONE. I wanted to know the difference between 1400s and 1650s. Hope this helps…
Those ARC 1650s are wheels that we custom make for BMC, so they have a virtual but not literal place in our aftermarket lineup. In other words, they’re their own thing!
The main difference between the ARC 1400s and ARC 1650s is the hubs - ARC 1400s have 240 hubs, ARC 1650s have 370s.
Key specs for your rear ARC 1650 80mm wheel:
  • DT 370 12x142mm hub
  • Drive side spoke: DT AeroComp 246mm SP
  • Non-drive spoke: DT AeroComp 251mm SP
  • 17mm internal rim width
  • 19mm wide tubeless tape
  • 87mm tubeless valve
  • Net weight of 1,003g
Key specs for your front ARC 1650 62mm wheel:
  • DT 370/350 12x100mm hub
  • Disc side spoke: DT AeroComp 266mm SP
  • Non-disc spoke: DT AeroComp 267mm SP
  • 73mm tubeless valve
  • Net weight of 810g
