so quite a few pools seem to be closing at the moment, so I was wondering if people could point me to some good dry land swimming workouts to do for the next few weeks to retain some sort of swim fitness. unfortunately I will not have access to a pool for at least 2 weeks. possibly longer.
There are lots of threads on here about using a Vasa ergometer or trainer. I’ve contributed on a bunch of those. I’ve used both, and with either I was able to “only get wet when I raced”, and actually be as fast if not faster than when I did pool only training. (It is easy to get in more training time, as you get back any time related to getting to/from the pool. So even if it is less specific training, the volume makes up for it.)
Interestingly though is that I also used stretch cords. I went through a period where I was travelling for work, so I bought a light and mid-weight set of stretch cords. I’d hang them from the back of a hotel door, and do whatever workout I would have done had I been going to a pool or using the Vasa. I’d use one, the other, or both combined for sprint intervals. And I had the same results as with the Vasa; no change in swim fitness when it came time to race. (I did workouts up to 1.5 hours. Put a computer on the floor and watch videos if that helps.)
Note that the longest period I went “stretch cord only” was about 3 weeks. But even then I maintained all the swim fitness I had. Note that with stretch cords they will put a lot of stress on your shoulder for the return stroke. For the most part I just let my arm follow the same path as the pull for the return in order to avoid too much stress on the shoulder.
Shiela Tamorina has several good ones in her book series “swim speed secrets”.
I tend to keep it simple and just do something that simulates 20x100 (:20) or similar. If I want to do 50s, then I’ll increase the resistance to the next harder chords. I also use a metronome set to my typical stroke rate for whatever distance in emulating.
I don’t think stretch chords get your heart rate high enough to keep the blood vessels “in shape” to deliver oxygen to your upper body.
The problem in swimming is NOT Strength. If it was 12 year old age group girls would not be smoking us. They have more power for their weight than us meaning they can deliver more oxygen for every ounce of meat on their body than us.
The stretch chords will help us improve technique. I think you need something aerobic for the upper body. A lot of my best swimming in tris has come across great XC ski seasons. Right now, I see the concept2 rowing erg maintaining all the upper body aerobic fitness than swimming can every load me up with. Some specificity on pulling down versus pulling up is the only delta. Stretch chords would take care of that.
Then you aren’t trying hard enough! There’s no magic to being in the water to make you work.
But, here’s the thing. You might be surprised at the pull force generated while swimming 1:30 pace. For me it’s 50-70 lbs when I swim tethered to the pool edge. Think about that for a second…if you are swimming 36-40s 50s, you are probably pulling 80-100 lbs or so, 22 reps per arm, rest 20 seconds and repeat 20 times. That’s not far off from a strength workout.
I err on the lower end of that for stretch chords… And then adjust the tension by backing up until I’m appropriately tired at the end of 1:40. My heart rate gets up there and I sweat like a pig. Again, I use a metronome to ensure I’m at the right rate for whatever pace I’m simulating.
I used this method 2x per week last year in my 100/100/100. I promise if you pull hard, quickly… You’ll get tired and your heart rate will get up there.
thanks!
Samira my gym-coach, has been doing some workouts for no-gym. She is taking a swim-specific course this semester i can ask her to post a workout for swimmers. Here’s a good general workout as an example:
I agree for the most part with this. Vasa and stretch cords really hit muscular endurance, but it’s a lot harder to get sustained aerobic activity, at least from what I’ve found. Sure, I can get my HR to LT on my Vasa, but that requires a very hard effort from me - the type of effort that I’ve learned is best reserved only for races due to burnout and fatigue. I don’t focus on HR at all on my Vasa, I focus on giving my arms/lats/delts the beatdown they need to not weaken over distance.
The stretch cords actually definitely give more pure short-burst ‘strength’ than the Vasa. The max resistance on a Vasa erg is still too low to do weightlifting type 10-15 rep pulls to failure, but it’s not designed for that. Whereas on stretch cords you can easily get cords that will be hard like weights, meaning you will be at failure at 15 or less reps. The truth though is that that type of low-rep strength is really good for sprinters, and not helpful for triathlon distance swimming where you have to pull for 20+ minutes. Kinda like doing heavy leg press sets of <15 reps won’t improve your 5k run pace, and probably not even your bike 40k pace.
Luckily, we triathletes get plenty of aerobic training from run/bike, which I found DOES cross over to swimming if you have the muscular endurance in the swim motion to tap into it.
I’ve got an antique Nordic Track ski machine… and its surprising how close the arm cables are, to a swim pull stroke. Especially if you lean foreword, think swim, and specifically mimic the stroke. If my pool closes, that machine will be put back in my workout rotation.
For some swim simulation exercise when I can’t get out of the house, I rigged up some light dumbbell weights to ropes, through overhead swivelling pulleys and connected to some handles for grip. One for each arm.
So I’m pulling down on the ropes (more or less, I stand back a bit because the weights tend to swing around a bit if not careful). Can sort of simulate a swim stroke, though you have to be careful not to overextend because you’re getting the full weight at the catch which can strain the shoulders a bit. Butterfly stroke seems to work best.
Stretch cords for sure , or a Vasa trainer, are best for maintaining direct swimming motion fitness.
Jump rope if you want to do aerobic fitness while also using some upper body. Plenty of youtube videos to keep things fresh, mix in plyometrics like jump squats and pushups.
Build swim-related strength through pullups, straight arm press downs, lateral raises, dips, etc, depending on what gym equipment you have access to.
One specific workout I like to do to incorporate upper body with aerobic work is to run on a treadmill for 5min to 1mile, jump off and do a short circuit set like 12 pullups, 20 goblet squats, 20 pushups or dips, then back on the treadmill for another cycle (no real rest between exercises longer than a sip from a water bottle). Repeat for 30-60 min. You could also throw some swimming stretch cords between the run segments instead of the circuit.
I don’t know where you are, most of pools here are closed (DC area), my guess is they probably won’t be open for at least a few months unless this whole thing blows over.
I have a Vasa, but think the following applies to both the Vasa and the Stretch Cords(if you lay down, not sure about standing):
Look at the videos Sheila Taormina has online and consider purchasing(or making if you are handy) a HALO template. Putting the HALO in place and working to generate more force in the high elbow position has been a big help to my improvement over the last couple of months.
I’ve been hitting intervals and shortening the rest progressively over workouts. Once the interval needed approaches zero, progress to more resistance and repeat the process.
What was the normal list prices? I just checked and read the lamest excuse they gave for a price increase, that company can burn in hell now for all I care. Agree about the swim cords, they kept me swim ready while I was in Afghanistan or Iraq.
