I’m wondering if anyone can tell me approximately how much dropout adjustability they have on their TT/Tri frame, as I’m contemplating getting a Tri/TT frame and setting it up as a fixed gear, using the dropout adjustability to achieve proper chain tension.
I’ve been having the hankering for a new aero fixed gear bike for long solo rides and was thinking of building up something like one of these:
as a fixed gear. The plan would be to get some carbon clinchers (probably 50-60mm front, 80-90mm rear) built up around a track hub with a longer axle and some spacers, a 165mm crank and at least a front brake. My riding is in mostly flat-rolling hills, and I’m an experienced fixed rider (see below). The other alternative is to get a nicer aero track frame (Cervelo T4 ideally) with a drilled road fork and set it up with a similar build.
I’m wondering what people’s thoughts are on this, especially if anyone has experience with something similar (TT/Tri bike set up fixed). I know I won’t have nearly the range of adjustability on the gearing with the short dropouts of the TT/Tri frame, but I’m hoping it will be enough to make the gearing work without an eccentric Bottom Bracket.
Any tips, thoughts, advice would be greatly appreciated.
Now for a bit of background on me and the project. I’ve been riding fixed for about 15 years now. Currently my main fixed bike is an Independent Fabrications steel Planet Cross that was designed to be Single Speed only. A few years back, after I had settled on cow horn bars as I was always riding it on the road, I added a set of clip on aerobars to it and have used it primarily for long solo rides as an alternative to my geared road bike. The bike is anything but aerodynamic, and the dimensions are all wrong for me for an effective aero position. I also converted my old 1993-ish Trek 2200 (aluminum lugs/stays/fork, carbon main tubes) to a fixed gear for commuting purposes about 10 years ago. I think the commuter has reached the end of it’s life, thus the reason for the plans above. The IF will be “retired” to my commuting bike, which means it will actually get more use than it has now, and I might even take it out for a bit of actual cross riding as well.
