Drilling C2s for internal routing
The Syntace C2s have exit holes for internal routing of the shifter cables, but there is no matching input hole.
Has anyone drilled their C2s for internal routing of the cables?
Any suggestions for what do to, or more importantly, what not to do?
-A
just drill a 5 mm hole right before the bend and make it a bit elliptical to make the housing enter the bar in almost parallel direction
Rocco is right, just drill straight into the bar, then slowly begin tilting the drill to make the hole elliptical. The more elliptical it is the smoother the cable will enter the bar. Also, dont put the hole too close to the end of the bar, like 3-4 inchs down from the bar ends.
