just “tried” on my wetsuit, and boy–it’s a great suit…just not so much on me. maybe it’s too small? it feels tight on my chest and is a little clausterphobic’ery.
i don’t know if that’s normal.
but aside from that: here’s what i got in mind for Little Smokies Half (please help)
-swim in tri shorts with tri top
-T1, stip tri top in favor of full front zipper cycling jersey (it’s easy to put on with full zipper. also has e-gels in pocket)
-T2, strip cycling jersey in favor of running singlet (that’s pink!)
i would just swim in sports bra and shorts, but feel too embarrassed.
this is a difficult course, so i’m not freaking out at my time, just want to have a good day and be prepared…if i need to spend 60 more seconds in transition i’m ok with that (i think). also, my tri top isn’t adequate for the gels; and my boobs are too big to run in it.
Kitty, why not wear the cycle jersey under the wetsuit and then you won’t have a problem with changing, although that shouldn’t be a problem for a specialist in covert extraction like yourself.
You have THE best profile, I liked the torch singer!
Jo, is it the wetsuit or jersey that is sleeveless? If the latter no problem, if not then it’s not an option. Go and have a swim in it asap so that you know what it’s like to swim in. Have no fear, you will find it easier to get off when it’s wet.
Put on SPF 50 on at the hotel, then put Body Glide on your ankles. That’s the only point of significant friction. Take your time when you are in T1. It’s a long race and nothing slows you down when taking off a wetsuit like trying to yank it off too quickly.
As for the rest of your garb, I would just wear your whole ensemble under the wetsuit if it’s sleevless. The wet clothes will keep you cooler on what should be an extra hot day.
“if i put pam on to make it go on easier, won’t that just cause me to sunburn?”
Huh? what does Pam® have to do with sunburn. And yes, it will get you out of the wetsuit MUCH faster. And NO, it won’t damage the wetsuit.
Wetsuits are meant to fit tight, and they take some getting used to. Try to get an hour or more of practice time and then keep using it periodically until it doesn’t mess with your head anymore.
“maybe i could just swim in the wetsuit, with sports bra/tri shorts, take the thing off in T1 and continue on with my cycling jersey and singlet plan.”
Why not just ride and run in the sports bra? Time in transitions can kill your race. Whatever you decide to wear on the run is what you should wear under your wetsuit and then onto the bike - - except for shoes!
