After scouring slowtwitch, general consensus is BTA is fastest and the BTS is second fastest with bottles on the frame to be generally avoided. I took my hydration setup outdoors for the first time today in preparation for my 70.3 next weekend.
This looks incredibly goofy, but should it be the fastest setup? FWIW, the cage on the downtube will be gone.
My main concern would be how much it would affect the handling having that much weight right on the handlebars. But I guess if you balanced it out over the steerer tube correctly maybe it wouldn’t be an issue?
I noticed that it was pretty squirrelly at first, but I pretended it was because 90% of my training is on the trainer.
I lost the reversed bottle at one point, but I’m going to use another cage I have that’s a little firmer.
IIRC, Tyler is also using bungees to secure the bottles in the cages. you might be better off doing that than trying to force a bottle into a tighter cage.
Second what Jason said. The cage that you’ll find that holds a bottle that tight probably isn’t worth the money it’ll cost. On my BTS cages I put a full bottle in and then use electrical tape to run across the cage arms. After removing the bottle, I run another strip on the inside to cover up the sticky side. I haven’t lost a bottle with this and it only cost me 4 inches of electrical tape. I’d do the same in your situation with the backwards-facing BTA.
I tried it & reverted to a single bta because of how it impacted the handling.
I don’t see why this would have much impact on handling unless you have moved the front bottle way forward from normal location but in those shots it doesn’t look extreme.
The rear bottle is pretty much over the steering axis so adding very little moment of inertia to the steering.
It is worth considering how many bottle you really need and of what size. In the picture it appears you have 2 tall (750mL) bottles and one normal (500mL bottle). Just by changing to 2x500 mL up front will give you some extra room and make things less awkward.
There was thread on here last week about the ideal number of bottles for a 70.3 and the answer depends on how comfortable you are grabbing additional fluid from an aid station on course. Personally I would run either 3x500mL bottles or 2x750 bottles depending on how many bottles of pre-mixed drink I wanted to use. I think aerodynamically your set-up is fine but I would be worried about losing the reverse facing BTA.
Incidentally, I used a similar setup for an IM but with the rearward bottle acting as a storage container for gel sachets. I cut a flap in the top of the bottle for taking out the sachets. It worked very well. Far more space than most bento boxes. My gels would have been a little lighter than a full 500ml bottle but not much. No handling problems and didn’t get in my way.
It’s a hot 70.3. All the bottles will have a scoop of scratch and I’ll be supplementing with shot blocks—1 sleeve (200 calories) per hour. Anticipating a 2:20 bike.
Why not just run an aero bottle on the frame as the third bottle? Personally I’d be doing that or getting the profile FC35 bottle if you are running the same in each bottle. I can understand why people may do it to separate their different nutrition but unsure why you need too? Also maybe fastest in aero but time lost each time you have to take a drink?
