I usually let a bunch of water in, which floats the suit to where I want it. And then get back out of the water and let the suit drain. It’s pretty much vacuum sealed to your body at that point. You can do basically the same thing by sticking your face in the neck hole (while in your suit and zipped up) and inflating the suit with your breath.
Yep let water in before the start, it allows the suit to move around and loosen up the tight spots where it’s been stretched while putting it on. I have seen people blowing air into the sleeve, haven’t tried though.
You do know that’s how a wetsuit works and keeps you warm, right? Light layer of water between you and the suit that quickly heats to your body temperature and insulates you. It doesn’t keep you dry.
yes, i do know about the insulating layer of water. that’s why i was surprised to hear more than a couple of people say it doesn’t matter.
Exactly…can’t start any race without the baptism of the wetsuit first. It’s a tradition & don’t think there has ever been a race when I didn’t. Oh, don’t ever ask to borrow my wetsuit…just advising here…
My question has to do with letting water down the neck of your wetsuit during your warm up?
If you want to maximize the performance of your wetsuit, yes, you absolutely need to do this. Water will creep in on its own, but it happens too slowly, but you don’t have that kind of time before the start. The scooped water and some swimming right after doing this allows the wetsuit to properly re-distribute itself (fit-wise) on your body. Plus, it sets up a layer of water between your body and the suit so you can warm it up.
The key is to scoop some water into your wetsuit, swim a little, and then climb out of the water and stand up. Excess water will drain out as it should. Now you’re ready to go.
