Anyone tried making their own aerobar pads? It’s not that I’m cheap - but I have a pair of Xentis aerobars that have been discontinued and can’t find the pads anymore. I bought a set of the CeeGees Xentis pads, but they’re way too small and they don’t return emails (thanks guys…)
I’m curious what material works best, and where to buy it. I was thinking maybe neoprene, but wasn’t sure what the best material would be.
1/2" Closed cell polyurethane foam pad and spray adhesive (follow can direction) can be found in the form of walking pads. Interlocking play mats or just as raw material. And, you may not be that cheap, but I sure as hell am.
Got some foam knee pads from home depot and cut them up. Much better than any pads I had before. The foam does’t absorb any water, and also never gets slippery even when pouring sweat.
I took a neoprene laptop sleeve (promo item from my wife’s job), cut it up, stacked a few layers (with 3M Super 77 spray adhesive), attached to my aerobars with velcro strips, and then trimmed to shape with a razor blade.
McMaster Carr (http://www.mcmaster.com/) has numerous materials that can be potentially used for AB padding. Check out items 8785K21 and 8991K58. Both are 1/2" thickness. Hope this helps.
First iteration I glued closed cell foam cut from an old camping pad directly onto the cups. The pressure of my arms pushed the foam into the 3 pairs of screwholes and didn’t work more than half a season. The second iteration, I cut 0.060 kydex sheet the same size as the cups, heated it up in the toaster oven and form fit it to the cups. (Profile designs by the way), glued the foam to the kydex and installed with velcro. That allows me to adjust the cups if I need to without ripping off the glued down foam, it also raised my arms up about 1/3 " without adding and spacers under the cups. I’ll post photos later,I’m not where the bike is right now.
