Disc Wheel Inflation Thingy
Can someone please point me to a site where I can buy one of those brass inflator adaptors for my ZIPP disc (the little 90 degree gizmo that goes on the valve so you don’t have to bend the valve out of the hole)? I just discovered that I lost mine. The ZIPP site doesn’t have them and Google didn’t yield any workable results.
Thanks in advance.
you mean the crack pipe…think silca makes it but not positive.
just go to your LBS and ask for a “crack pipe”
http://www.trisports.com/sipudiwhad.html
That’s it. The Crack Pipe. Thanks for the quick replies.
They have them at the online store at hedcycling.com.
Bob C.
Some LBSs don’t carry them unless they are a Tri shop too. I contacted a LBS that did not have them and gave them the info on Silca and the part number and they special ordered it. After two days they had it for me and I got it for 9 dollars instead of 13 and did not have to pay for shipping. Works great, just press it on hard to the presta when you pump with it and you’ll be able to pump with one hand while holding it steady with the other. Some here complain it cannot be done w/o two people, but that’s not true unless your friend is holding a beer for you.
Crack is so 80’s. To be current, shouldn’t we be calling it a “crank” pipe?
