Disc out of true?
Hi, I seem to have a fair amount of side-to-side wobble in my Renn 575 disc. I have to let my rear brake all the way out or it will rub. I’ve only ridden it probably 5 times and haven’t crashed it or hit any big bumps that I can recall. (I haven’t taken it off any sweet jumps, either) Is there anything I can do to correct this?
Your other rear wheels seem OK? Is the wobble always inthe same place when rotating the wheel? DOes the wheel move if you try moving it laterally in the dropouts? If you are mechanically inclined, you could try disassembling it and seeing if the axle is straight. Check by rolling the axle on a table and looking for a wobble. After that, or if not mechanically inclined, contact Renn.
I had the same problem with my Renn disc. I contacted them via email and they replaced it right away.
Call Frank at Renn. He’ll take care of you.
email him/call him.
he just replaced mine…amazing customer service!
Thanks all, an email is out to Renn.
