After riding the same road bike for 10 years, I started thinking it’s time for a well-deserved upgrade, and I bought a Specialized Tarmac Disc Pro – it has ultegra hydraulic disc brakes. Before I bought it I asked anyone in my club who I saw with disc brakes how they found them and the response was always the same – “They’re great!†I read articles and online reviews, and did not feel that the ‘cons’ that were mentioned were of any major concern to me: a little heavier, a little less aero, slight possibility of rotor causing injury in a crash… I’m all about safety, and I thought the sense of security that I would feel when riding in the rain, or if I were ever lucky enough to do an epic descent somewhere like in the alps or the pyrenees, were well worth any of those cons.
So now I’ve had the bike for a year, and the brakes will not stop rubbing. I take them back to the bike shop to get adjusted, and they’re okay for a while, then they start up again. Usually just when I’m going up a hill and riding hard out of the saddle, but lately it’s been worse. When I mention it to others, they say, “Yeah, mine do that too. That’s disc brakes.†So how come nobody mentioned that before? I love everything else about the bike, but the constant noise is really irritating. It’s hard to enjoy a quiet ride in the countryside, when you keep hearing “tsst… tsst… tsst…†A friend with the same problem also keeps going back to the shop, and he says he is expecting that there must be a way for them to eventually get dialled in, his argument being, “Do you think Peter Sagan puts up with this on his bike?†My response was No, I don’t, but he gets to have his disc brakes (along with the rest of his bike) tuned before every ride, whereas the rest of us are not so lucky.
I feel like this is something that should get mentioned more, when people talk about pros and cons of disc brakes. I would not have bought disc brakes if I had known they were so finicky. I really dislike riding a noisy bike. Am I the only one? Sorry for the rant, but just had to get it off my chest.
If they rub i adjust them. It takes no more than a few minutes
If they refuse to stop rubbing it’s usually a bent rotor. Most of the time I can fix that with an adjustable wrench
The one time I couldn’t I got a new rotor.
There are a bunch of YouTube’s. The business card trick will typically fix even the most annoying issues
If your brakes rub, they shouldn’t. I think that’s why people don’t complain. It’s so easy to fix
After having disk brakes for the last decade on my mtb, if you are getting rubbing all the time, either your calipers need to be pushed back in with a brake block or your rotor is warped.
Also having ridden rim brakes with my cross bike for the last 4-5 years, the occasional rub which csn be fixed still outweighs the performance of rim brakes.
it should be temperature related only… for me heat related and after a while it stops
Yeah, part of the thing/joy with rim brakes is that you can dial them in just so. But then as pads wear, they need further adjusting to be just so. So they are kind of high maintenance (maybe less so for the tt crowd).
Disc brakes require love too. They are not set and forget. Well, they are on my xc, cx, and fat bikes. But maybe i am less obsessive about listening for rub.
My sram s900 brakes rubbed up front at first. I straightened the rotor slightly… but slight rub kept returning after a ride. it resolved when i finally did a proper bedding protocol… well, no rub after three rides. Fingers crossed.
The tolerances seem very close. Not much room for error it would seem. Hopefully future versions will solve it… but then disc brakes are hardly new for mountain bike…
Because most people are deaf.* Disc brakes inevitably rub with heat and use.
The good news is that truing them usually isn’t much trouble, since the truing process involves just bending them back into shape. If it’s something you’re picky about, learn to fix it yourself.
*This becomes annoying during group rides in the fall and rainy season. Sometimes I’ll have to point out to someone that the whining noise their bike was making was a leaf jammed against the tire, and they’ll respond that they didn’t even realize that their bike was making noise.
Sometimes the rain bikes themselves are a noisy mess, which is part of why I despise the whole concept of “rain bike.” I have a couple bikes that I only use in the sun, but I don’t have any wet-weather specific bikes that I don’t enjoy on good days. If a bike isn’t a joy to ride in great weather, it’s not going to be a joy to ride in the wet either, so I should fix what’s wrong with it!
They’re fairly easy to adjust, only takes a minute or two. What I do find occasionally happens is grime or dirt will build up on pad and sound like rubbing. Usually goes away by “cleaning” with a few hard stops.
Oh, it gets mentioned…along with pointing out the tendency for them to also squeal more upon application…but those voices usually get shouted down, typically with accusations of Luddite-ism. :-/
In the end, the tight pad to rotor clearances required on hydraulic discs are the result of using a relatively small braking surface at a relatively small diameter, and with materials that aren’t super “grabby” (relatively speaking)…all of which means that the piston forces need to be quite high for a given braking torque. Since the travel is basically defined by the piston seal rolling (and is pretty much linear) this means (combined with the high force required) that the piston travel distance is quite small. It’s a leverage thing…you can trade off travel for force, and vice versa. On many vehicles (such as cars, motorcycles, etc.) the pads actually rub almost all the time…but, those aren’t powered by mere fractional hp “engines”, so the additional drag isn’t really noticed…it just is what it is.
Oh yeah…I’ve found that one of the nice things about using cable actuated discs is you can adjust the pad clearance up or down as necessary. Sure, that also means you need to periodically adjust them for wear as well, but that’s a pretty minor annoyance. Folks tend to say that the cable-actuated models don’t perform nearly as well as hydraulic, but that’s really only true when comparing to ones that only move one pad and rely on disc flex to press against the other (such as Avid BB7s, etc.) Set up with solid, link-type cable housings, the power transfer on dual sided actuation models (e.g. TRP Spyres) really doesn’t give up much, if anything, to hydraulic actuation IMHO.
The pads are self-centering, but they sometimes need to be more centered. https://amzn.to/2NmVgWr Jam something like this in there to recenter the pads a bit.
Housing type and routing can matter as well. The big benefit of hydraulic actuation is that it introduces almost zero sponginess, even with tight housing bends.
As long as it’s bled correctly…and often
I find discs require a lot of attention to maintain a modicum of good behaviour.
For instance, my bike cleaning routine:
- Remove pads and rotors
- Clean bike
- Light sand then alcohol rub for pads and rotors
- carefully lock pistons in fully extended position and polish the barrels as they often get sticky so one side doesn’t retract properly
- lube bike
- reinstall rotors and pads
- check rotor trueness
Enjoy some quiet riding with OK braking until the next time the roads are wet and grit gets in there or they start squealing.
Bleeding is less frequent, but definitely a chore
I said this frequently and often about two years ago but got shouted down by the disc brake mafia. Glad I kept rim brakes on my road and TT bikes.
I must be an outlier. I have a 2017 Roubaix with hydraulic disc brakes. It has about 12,000 miles on it, and they were hard fast miles in adverse conditions, and my front brake has only had basic maintenance from the LBS in the spring of 2018 and 2019. I’ve never had rub, abnormal noise (except for a few races in the rain), or had to do any type of corrective maintenance. I’ve used my back brake only a few times so it doesn’t count.
A few weeks ago those disc brakes saved a small boy’s life when he darted out into the street while I was hammering along at about 25 mph. The bike stopped on a dime. A car or bike with rim brakes would have never stopped.
When you need them they are worth every penny you’ve spent.
Basically this,
Here is a good video from GCN
https://m.youtube.com/watch?v=gQ_oIAPuQR8
Maurice
As long as it’s bled correctly…and often ;-)Not sure I agree with this - my road bike is about 14 months old and I’ve never had to bleed the brakes.
Well, like most of these things, it depends on usage. If you spend a lot of time heating them up on long descents, you’ll be bleeding more often…if not, then not so much. I’m comparing the results of the former, not the latter.
- Clean bike
- lube bike
Bleeding is less frequent, but definitely a choreI agree with you - I love my disc brakes but they require a ton of maintenance. For some reason my rear brake is much more stable whereas my front brake needs much more TLC. It’s one these things where, if you choose to ride with disc brakes, it’s a must to learn how to true the rotors, realign calipers and clean the pistons.
Well, like most of these things, it depends on usage. If you spend a lot of time heating them up on long descents, you’ll be bleeding more often…if not, then not so much. I’m comparing the results of the former, not the latter.I live by the San Gabriel mountains and ride there quite a bit and on my local climb I’ll usually get stuck behind cars and will need to brake the whole time so that by the time I’m at the bottom there’s a constant rub from the heat which then goes away in the next 15-20 seconds. Maybe it depends on how much is ‘quite a bit’, but so far so good. A long time ago I used to find bleeding such a pain in the ass on my mountain bike that I switched from hydraulic to cable actuated disc brakes, and that experience made me think long and hard before pulling the trigger on going with disc brakes on my road bike last year. No regrets however.
If your brakes are constantly rubbing, just loosen the caliper bolts, hold down the lever and re-tighten the bolts. That solves 80% of issues. If it’s a tick… tick… tick sound, the majority of the time, the pads just need to recenter. This happens automatically on hydraulic brakes and the ticking will go away quickly. If the ticking doesn’t go away, the rotor might be out of true, something you can fix with an adjustable wrench or even just your fingers and a paper towel. Most rotors come with a bit of runout.
A few things I’ve noticed:
Shimano post mount brakes are easiest to adjust and most tolerant of slight amounts of rotor runout.
SRAM calipers are a bit more finicky to setup but still not a problem. The tolerance and pad movement both seem to be a bit tighter.
Shimano flat mount calipers are very finicky to setup and tend to rub the most. This is a dumb standard, IMO, expecially given that the pre-existing post mounts work better. Still, you can get them working fine with some patience.
Also, roadies are far more sensitive to rotor noise than mountain bikers. Don’t worry about it so much.
