I’ve read a lot of online ‘reviews’ and experience and seems to be a mixed bag. I’m looking to use 11 speed on my existing 10 speed Quarq…all other components and wheels will be 11 speed specific… Most accounts indicate it doesn’t cause any major issues, but can impact shifting a bit or could cause rub in the small ring and smallest cog.
You could always put 11 speed chainrings on the quarq right?
anyway I currently have shuimano 11 speed running on a 10/11 speed big ring and a 9/10 speed inner ring…a cheap crappy 9/10 speed inner ring. Shifts fine.
I’ve just upgraded to 11spd Di2, but left the 10spd chain set. I haven’t noticed any difference in change quality. Wouldn’t know about the small/small combination, as there’s no reason to use that combination. If it does make a noise, it’s probably a good reminder that you should be in the big chainring
A 10 speed rings can be used with 11 without problem but… the front derailleur has to be specifically for 10 or 11, although you can save the situation with a 10 using a 11 chain…
In the back 11 speed specific chain+derailleur+cogs are a must.
Yes…you could put 11 speed rings on the quarq but that won’t make much of a difference if any as the internal dimensions of the 11 speed chain are essentially the same as the 10 speed. As I understand it the outer width is less and as a result the spacing of the chain rings is different on 11 speed specific cranks to account for this.
Yup same here. 11 spd everything (Ultegra Di2) except 10 spd Quarq crank/10 spd chainrings. All is good. No trouble shifting and never dropped the chain even once (pretty sure anyway) in six months.
Ahh, I did not know that.
I suppose one could make chainrings to account for that too, don’t know if anyone has. Appears that it may not be cessary.
Add me to the list of those using 10-speed cranskets/chainrings with 11-speed components with no issues. I’ve used both Shimano and Sram with the same results. DA 7900 SRM with Ultegra 6800 components, and Quarq w/ 10-spd rings and Force 22 components.
I am running 11 speed on SRAM Red 10sp cranks and a SRAM Red 10sp Yaw front derailleur. I didn’t notice any drop off in shifting performance when i switched to 11sp.
For what I know the 11spd front derailleur is just a bit narrower to fit the 11spd chain, the 10spd is a bit “wider” not sure about the exact tolerance. For a perfect fit 11-11 and 10-10 chain-derailleur (front). The back part of the train is a must to have the same.
It is true that 10spd can accommodate a 11 chain, not a big problem… but the design is not made for that, it will shift and at the end you don’t shift so many times the front as the rear train.
The rings are the same as the inner space of the chain is the same. What is different is the wall. Well at least when I did a test on my own at home the last year.
Just went in to check out a new P3. Very nice. However, my shop was adamant that my BB30 10-speed quarq cinco wouldn’t work with the 11-speed ultegra drive train. Is this exactly what you are successfully running?
I have 2 Quarqs, one is a Red and the other is an Elsa. The Red has 10 speed X-Glide rings and the Elsa has 10 speed PowerGlide rings.
The Red is paired with a Red 22 group and the Elsa is with a Force 22 setup. They both shift up and down wonderfully.
With the PowerGlide rings, there is some chain rub (chain rubbing the big ring) when I use 34 with 11 and 12. The XGlide rings avoid this issue because they have material removed from that area to prevent chain rubbing.
FWIW: I have tried to measure a Red (10 Speed Yaw) and Red 22 Front Derailleur dimensions and can’t come up with any differences, if it’s there, I’m not seeing it.
I’m running 11 speed SRAM with a 10 speed SRAM Red Quarq. It works just fine. I get a little chain rub in the small ring and small cog, but you should never be cross-chained that badly anyways…
Another person with Ultegra 6800 everything except the Quarq SRAM crank.
Oh, Also running a SRAM S950 crank, Power2Max and chain rings with an Ultegra 6800 setup on my road bike.
