Composites, materials made of a combination of other materials, such as carbon fiber and carbon fiber composite (carbon with ceramic, polymers, metals, etc.) are
anisotropic or have anisotropy, the ability to behave differently over different directions.
Rocks are often composites. Some rocks are worthless and crumble rather easily, others are extremely hard and dense or have radioactive properties.
Anyway.
Carbon fiber can be configured in many different ways producing tangibly different results. Key word: Tangibly.
Cost is an attendent result of adding different materials and processing those materials differently, and the material itself. Additionally, there are attendant costs to the lay-up procedure and other processing factors.
This is a reasonable question because there is so much “smoke on the battlefield” of carbon fiber marketing. Just what is “Di-Preg Multi Laminate Ceramo-Carbon Matrix”? or “Ultra High Modulus Uni-Directional Nano Tube infused Carbon”?
Too much marketing BS. This valid frustration over BS causes the inevitable, ill informed forum responses (you’ll see them in this thread, I’m behind one now) that make sweeping generalizations in a gulf of real information like, “They are all the same- the only difference is marketing…” “They all come from the same factory in Taiwan…” and the usual forum flotsam.
The truth is there are test-able and viable differences in carbon fiber in the bike industry and in other industries. It is getting to the bottom of what those differences really are and how they tangibly change the product and cost that is challenging- but the differences are there.
There are websites that have some good information on the carbon fiber that suppliers of the raw material produce. It is true there are far few producers of the carbon tow than there are the carbon products that come from them. It is the same with carbon bicycle frame factories.
Here is an example of some of the materials available:
Comparison of Carbon Fiber Manufacturer’s Products Fiber Type Fiber Name Manu. Tow Sizes
(K) Tensile Strength
(GPa) Fiber Elong
(%) Tensile Modulus
(GPa) Comp Strength
(GPa) Fiber TC
(W/mK) Fiber Density
(g/cc) Pitch Fiber XN-50A NGF 0.5/1/2 3.9 0.7 517 0.4 180 2.14 YSH-50A NGF 3 3.9 0.7 517 0.6 120 2.1 P75S Cytec 0.5/1/2 2.2 0.4 517 0.4 200 2.0 P75SP Cytec 0.5/1/2 3.4 0.7 517 0.5 - 2.15 K1352U Mitsubishi 2 3.7 0.6 517 0.4 140 2.12 K13710 Mitsubishi 10 3.4 - 634 0.4 220 2.12 P100 Amoco 2 2.4 0.3 758 0.3 - 2.14 XN-70A NGF 0.5/1/2 3.7 0.5 723 0.4 320 2.16 YSH-70A NGF 3 3.7 0.5 723 0.4 250 2.16 P100HT Cytec 2 3.6 0.5 758 0.3 - 2.15 K1392U Mitsubishi 2 3.7 0.5 758 0.4 210 2.15 XN-80A NGF 1/2 3.7 0.5 785 0.3 - 2.17 P120 Cytec 2 2.2 0.3 823 0.3 600 2.16 K13B2U Mitsubishi 2 3.8 0.4 823 0.3 260 2.16 XN-85A NGF 1/2 3.7 0.4 823 0.4 430 2.17 K800 Cytec 2 2.1 - 861 - 800 2.15 K13C2U Mitsubishi 2 3.8 0.4 896 0.4 620 2.2 YS-90A NGF 3 3.7 0.4 896 0.3 430 2.19 K1100 Cytec 2 3.2 0.25 930 0.2 1100 2.2 K13D2U Mitsubishi - 3.8 - 242 0.3 790 2.15 PAN Fiber M40J Toray 6/12 4.4 1.2 372 >1.2 - 1.77 M46J Toray 6/12 4.2 1.0 434 >1.0 - 1.84 UHM Hercules 3/6 3.4 0.8 441 0.8 - 1.88 M50J Toray 6 4.1 0.8 475 0.8 - 1.88 GY-70 BASF 3/6 1.9 0.4 482 0.4 - 1.96 M55J Toray 6 4.0 0.8 537 0.9 - 1.91 M60J Toray 3/6 3.9 0.7 586 0.8 - 1.94 Panex 35 Zoltek 3.8 - 242 - - 1.81 Panex 33 Zoltek 48 3.8 - 228 - - 1.81
Toray and Mitsubishi are the “Reynolds and Columbus” of the 1980s. Even though Pinarello and DeBernardi used the same Columbus tubes, one frame had a higher regard than the other.
Felt uses a blend of these fibers. Building a bike with 100% M60J wouldn’t be wise. Sure it is relatively stiff with low density (g/cc) but it may be far too brittle. That is where the blending of the “tough” fibers vs. the “stiff” fibers give bikes their balance of strength and rigidity. Identifying what fibers to use where and in what orientation and layering them in the right bias using uni-directional sheets and various templates and pre-cut patterns is the difficult part. Adding the nano-resin laminates also helps to add this strength to resist point loading and increased impact and “forgiveness”. This nano-resin may have such an increase on the strength that less material could be used for the same strength, or more of the brittle (but stiff and low density) fibers can be used with an increase in stiffness.
In short; simply knowing the ingredients, doesn’t bake you a cake.
To a large degree what most marketing teams set out to do is to distill the information in a digestible form so guy like me has some rudimentary understanding of what the guys in the engineering department are doing.
It is rocket science.
-SD
