For Sale, Diamondback Haanjo comp, this is a perfect and versatile set up for gravel / adventure type riding. It has a nice, wide spread of gears, huge 700x40 Schwalbe tires which hook up well on trails but roll nicely on the road.Tubeless ready HED wheels. Shimano 105 gears and disc brakes. Thru axles, rack ready fork for bikepacking. This has been used for less than two months and ridden about a dozen times in total. Sadly it is the wrong size for me. I am asking $1600 which is about $1000 less than the new price. More specs below
FrameDB Carbon Alternative Road Frame, Endurance Geometry, Relaxed Headtube Angle, Disc Specific, w/ 142x12 Thru-axle & Replaceable Hanger
ForkDB Gravel Disc, Full Monocoque Carbon “CFT”, 12mm Thru-axle Drop Outs, Flat Mount Disc Tabs, 1.5" Tapered Steerer Tube, Low-Rider Rack Mounts.
HeadsetFSA NO.42, Sealed Cartridge for Tapered Headtube
CranksFSA Gossamer Compact BB386-DB Evo, 46/36T
Bottom BracketFSA BB-EVO8681
Front DerailleurShimano 105 FD-5800, 31.8mm Band Clamp
Rear DerailleurShimano 105 RD-5800, 11 Speed
Shifter Shimano 105 ST-5800 Dual Control, 2x11 Speed
Corset Shimano 105 CS-5800
Cassette, 11 Speed, 11-32TChain
KMC X11L, 11 Speed
Front Hub 28h Alloy, Sealed Cartridge, HighLow Flange, 12mm Thru-axle w/ CNC Disc Mount
Rear Hub28h Alloy, Sealed Cartridge, HighLow Flange, 142x12mm Thru-axle, w/ CNC Disc Mount,
CassetteSpokes14g Stainless Steel
RimsHED Tomcat Disc, 24h, 21mm Internal Width, Tubeless Ready
TiresSchwalbe G-One, Performance, Folding, 700x40c
BrakesTRP Spyre Mechanical Disc, w/ 160mm Front / 160mm Rear Rotors
Brake LeversShimano 105 ST-5800PedalsWellgo Alloy Road
HandlebarDB X-Durance Gravel Bar, 8° Flare, 31.8mm Bar Bore
GripsEVA Cork w/ GelStemDB X-Durance 3D Forged Alloy, +/-7° Rise, 31.8mm Bar Bore
Saddle DB Eldorado
SeatpostDB X-Durance, Alloy 27.2mm
