i’m investing in two new set-ups: a classic XC (racing) set up; and a tele set up for alpine style skiing. i’m coming back to all this after 30 years, so, i’m in the dark. i need help!
fortunately, it doesn’t seem waxes, colors, etc., have changed, so i’my buying a couple hundred dollars worth of toko merchandise (most of the kick waxes, lots of green base wax as a base for everything, most of the klisters, none of the spray, all parafin style wax in keeping with what i’m familiar; corks, scrapers, irons and the like). why toko? because i’ve got a contact.
i likewise have a rossi/rottefella contact, so, i’m heading in that direction. here’s where i so far am, and, keep in mind that i’m 6’2", 170lb:
- Skis: Rossignol Delta Classic 206mm
- Poles: Oneway Diamond 9max 160mm
i need a recommendation in the area of rottefella bindings, and, rossi is fresh out of boots for this season, so, i need another boot and i’m hoping there is another boot that’s rottefella compatible. i have no idea what’s compatible with what these days, and how ubiquitous the standards are.
can you recommend bindings and boots? and remember, this is classic.
now, tele, i don’t expect you to know about this, but maybe you do, and if you don’t maybe somebody else here does. so far, i’m leaning toward a rossi phantom SC80 ski, and i’m guessing 180mm but i don’t know. rossi doesn’t make tele boots, so, i’m thinking garmont, but, i’m open. also, i’ll need a rottefella binding that is compatible with whatever boot i’m looking at.
again, this is a lift-up, ski-down use, not backcountry, and mostly on groomed mountains.
a little help out there? anyone? anyone?
