I have a Slice with a Cobb Vflow Max saddle in the ‘forward’ position. Is anybody else running this combo with an xlab delta wing? Does it fit and are you running a 200 or 225 (adamo specific) version? I have a lot of ‘post’ back there that I need to clear b/c my saddle is pretty forward.
If you don’t have a c’dale maybe you can answer if the 200 or 225 mount is best for Cobb?
The 225 just adds another bracket to clear the Adamo hooks and changes the bottle angle which might help. The Tacx mount should also work, but it’s seen mixed reviews.
I was able to zip tie a cage using the stock seat but I haven’t figured out how that’ll work yet with the Adamo. Use both the seat rails and the rear hole of the post to secure the cage.
Hi Jamie, do you have a picture of your forward seat position? That would help to judge if the Delta 200 will fit. You wouldn’t need the 225. That has an extra bracket to wrap around the hook on the Adamos. The actual mounts on both models are identical.
