Daniel's VDOT- EXCEL Guru's
Here is my objective:
Create an excel document which has VDOT Calculator in it.
I am thinking I would have to:
  • Create a drop down list to choose ‘test distance’
  • Create a lookup based on ‘test distance’ & time inputted by user
  • Link this to a lookup within the VDOT table to calculate VDOT. (Kind of tricky as it would have to be within a range of times)
  • Link the associated VDOT to a linked table which has the training intensities based on the calculated VDOT & output
Any ideas on how to actually do all of this or if there is an easier solution.
Pretty much, I want to be able to do what this online tool does in excel or replicate the same exact thing online for personal use (I know many people will ask; why not just use the tool that is already there- believe me, I have very valid reasons): http://www.runbayou.com/jackd.htm
Mahalo,
Daniel
Mahalo,
Daniel
A simpler/cleaner solution would be to use the published closed formulas to calculate VDOT from test distance and time:
  • VO2 cost of running a distance/time velocity (see Oxigen Cost formula)
  • %VO2max that can be sustained for time duration (see Drop Dead formula)
VDOT= VO2 / %VO2max
Then you can lookup Daniels Tables with VDOT value for training intensities or (better IMHO) calculate vVO2max from VDOT and use %vVO2max values for E-Pace (72%), M-Pace(85%), T-Pace(90%), I-Pace(98%), R-Pace (107% for 200m / 105% for 400m).
Equivalent performances is not so easy to do without table lookup, you could do it with Newton Raphson iteration as shown here
Hope it helps,
Thanks… I appreciate the inputs & am going to try it out.
Mahalo!
I’d just make an html redirect to the mcmillian calculator
Just wondering if you’d be willing to share what you come up with. Am really interested in seeing how it turns out. Thanks!
I fudged it for now…
Here is what I did:
Calculated the % of each training intensity for a prescribed VDOT to the VDOT’s 10k time. I did this throughout the entire VDOT table to make sure that the ‘pattern’ & %'s did not vary greatly. So, what I came up with is that given your 10k time…your training intensities at each level are about X% of your 10k time. Then, it is just a matter of multiplying those %'s by the athlete’s actual 10k time to come up with his/her training intensities. Listed below are the %'s but I used a range to give myself a little margin for error.
Not fullproof but a quick fix for now.
Easy: 21%
Marathon: 18%
T-400: 4%
T-1000: 10.72%
T-mile: 17%
I-400: 4%
I-1000: 9.45%
I-1200: 11%
R-200: 1.71%
R-400: 3.5%
Note: To do the calculations, it is easier to convert your times to seconds or as a fraction of minutes.
oh my god! I just looked at your blog and you are breaking rule 1 of what not to do on a website… do not automatically start playing music, ever.
I don’t know if this will help you, but I found a guy that was trying to accomplish the same thing by making a VDOT calculator in excel. Here’s his link:
http://www.twentysix-two.com/upload-excel-training-log-and-/
quite a nice table here http://www.electricblues.com/runpro.html (the zip file)
anything you want done with excel just ask and I can generally make it happen (assuming that it is within excels capabilities)
