OMG! It’s still alive!
with the standard frontal area of 0.5
Nobody ever measures “A” alone. What is the Cd in your example? If you used the 0.5 entry in A-Cycling.com, go back and start over.
- maintaining a steady power of 250 watts on both the up and the down and maintaining the frontal area of 0.5 on both the up and down.
- 400 watts on the up and 100 watts on the down with a frontal area of 0.55 on the up and 0.35 on the down
- 500 watts on the up and 0 watts on the down with a frontal area of 0.55 on the up and 0.35 on the down.
If you plugged 0.35 as “A” into ACycling, you got a CdA of 0.175 – which no human on a real road racing bicycle has ever achieved. You clearly still do not understand CdA and how it works.
Once again, you have proved that you do not understand the sport whatsover.
I am sorry, I simply plugged in somewhat “typical” numbers in the Acycling form. Acycling says the “effective frontal area” is “typically” in a range from .4 to .7. so .35 and .55 do not seem out of line to me to use for someone climbing and someone trying to maximize aerodynamic benefit. Whatever the number, these are simply numbers to illustrate a point in that climbing people are generally less aero and descending they are generally substantially more aero. I simply chose a number in the max aero position for effective frontal area that was not quite half of the climbing aero number. I could have chose .7 and .4 and gotten somewhat similar numbers I am sure.
The point is that hills do not have to have a major effect on overall times (if there is no net gain) if the hills are ridden smartly. While racing at a steady effort may be optimum when riding a flat course like Florida, it is not optimum when racing a course like Canada or Placid or one with lots of rollers. There is little benefit to be gained by riding hard on a substantial downhill if it will prevent you from riding at a hard effort on the next uphill.
As I stated, I did not calculate normalized power and I admitted that they did not have the same average power, but I explained why such a deviation might be “reasonable under the circumstances”.
I will admit that hills could have a devastating effect on average speed if one rides the course particularly stupidly. I was actually surprised it was as large as it was for someone riding at a constant effort. However, my point is that it doesn’t have to be and “constant effort” is not how most people actually do ride hills. The way that most people actually race hilly courses (harder efforts climbing, lesser efforts descending) lessens the effect of hills on slowing the average pace. I can see how hill repeats should be a big part of any build-up if one had one of the hillier IM on the schedule as climbing hard is the most important part of racing fast on a hilly course. At least to my feeble mind that is clearly unable to understand any of this stuff.
