I think hills have little influence on overall times …
Wow. I know a cyclist or two – ok, say about a couple billion of them – who might disagree.
Tom challenged you to do the numbers. Go ahead – run the numbers with a CdA going up of, say, 0.33 and coming down at, say 0.26. You are using words to support a mathematical conclusion (conjecture, really). You need to do the math.
You can’t just make stuff up.
The question is not are times generally slower on a “hilly” course, but why. It is unlikely that is it due to the aerodynamics of racing. It is more likely due to many other factors including to what you alluded to, being “timid” on the downslope, being afraid of high speeds or the need to brake on curves when going fast. If one could go faster on the downslope but doesn’t then that will slow them down. That “slowing” is not due to physics. Or, if one has to brake on corners because of speed on the downslope that will also slow them down but that is a technical descent issue, not a hill issue per se.
As I noted, the bike course records for a wide variety of courses are almost identical. Steve Larsen was 10 minutes faster setting the bike course record at IM Florida in 2003 than he was setting the Bike course record at IM LP in 2001 which might say something except LP was Steve’s first IM ever, and only third run as long as a 1/2 marathon (and first marathon) so I suspect he was holding back a bit on the bike at LP (plus his seat post collapsed on his borrowed bike so he rode most of the course in a sub-optimal position) compared to Florida where he was trying to make a statement after a dismal performance in Kona.
Most people don’t know either their drag coefficient nor their frontal area so such calculations are always a big fat guess…
Re-read the part about how it isn’t necessary to separate the terms. Nobody does, even in wind tunnel tests. Those figures are anything but a “big fat guess.”
“Frank (can’t be a scientist …”
Well, that about sums it up.
The numbers people put in at analyticcycling.com are big fat guesses as few have ever been in a wind tunnel.
I have already retracted my criticism of this portion of the document.
