I purchased a cycleops riser block (which said it could be used as level). However, it is never quite level. Even on the lowet setting, it seems to raise up the front end ever so slightly.
Does this sound right? I have a Jet Fluid Pro, so wondering what other front wheel blocks I could use to make it perfectly level.
I use a Fluid 2 trainer and found the CycleOps riser block to be too high as well. I started using the round KK riser a couple of years ago b/c of that and it seems to be pretty level on the lowest setting.
