I am cutting carbon aero bar extensions with a hacksaw later today and from what I have read online some say just to buy a blade with the most amount of teeth they sell (32 teeth), others say carbide blade (I am assuming its a ceramic tile cutting blade?). Let me know what you use. Of course I want to try to avoid any type of fraying of the carbon and plan on using painters tape over the area where I will be cutting.
Thanks
I’ve used a regular high tooth count blade every time have done it without any issues. I’ve found wrapping with electrical tape seems to help with any fraying/splintering better than masking tape.
This. You might want to clamp the bar into a jig before cutting so you can get it straight.
Yep ---- metal cutting blade ---- high tooth count is good. measure three times cut once
You can ‘wet cut’ by keeping the area damp during cutting
Keeps all the nasty carbon dust from getting everywhere
Thanks
32T high carbon steel blade. Did not use painters tape or masking tape and it came out just fine. Suggest that you: (1) wear a mask; (2) wear goggles or other protective eye wear; (3) cut outside; and (4) wash hands thoroughly after cutting. The carbon/resin dusts goes everywhere while cutting.
Thanks for the posts and the information. Going to give it a go later.
I’d second both the electrical tape (or if you’ve got some, hockey grip tape) and using a wet method (just pouring water works) to keep the dust down.
measure thrice, cut once and go slow to start until you’ve established a good straight cut then go all out. pipe cutting guides help, alternately, two closely spaced hose clamps to help make the cut at a right angle
I cut mine with a hacksaw. The problem that I encountered was the inside is only reamed out so far and the shifters would no longer fit without more reaming. It was a real pain.
I’ve used a composite-specific hacksaw ‘blade’ ~ it’s not really a blade in the conventional sense, though, but a rod coated in some sort of carbide grit… so in essence it’s kinda like you’re actually ‘sanding’ a narrow trough all the way through the carbon tube.
i use both kinds of blades. the only problem with the carbide blade is that some of them are too thick to go through my miter block (i have a cycling specific miter block for steerers, aerobar extensions, and whatnot). miter block goes in the bench vise. i’m sure this is heresy, but i will often just use my sawzall. i have carbide blades for my sawzall. i saw, or have sawn, right through, with the sawzall, using the miter block. i don’t see the problem.
