I’m gonna order a wheelbuilder disc cover in a few weeks and I want to do something with it that makes it stand out. It’d be really cool to paint an optical illusion on it, like Benham’s disk, or a three-dimensional cone: http://www.youtube.com/watch?v=G_XDJ0QRgxE
can I paint on one or is there any method to do so? I’ve read that they have a finish, not sure how it’d affect its customizeability…
I had the google chrome logo spray painted on mine before I upgraded to an actual disc. My chromed out rims got alot of comments
How well did the paint stay on the disc? The next thing I read was that with a lot of flexing the paint tends to crack really easily. I’m not worried about the extra hundred grams or so to make it look cool =P
I’m sure it’s possible to make the pattern, but you won’t get the same effect looking at it with your eyes in natural light. The weird effects can come from either using artificial light which cycles at some frequency (either 100 or 120Hz = double the line frequency of 50 or 60Hz) or from using a recording medium that samples the image at fixed time intervals. But if you just want it to look cool when someone videos you going by, then by all means go ahead!
So optical illusion disc designs don’t work? The wheel is going to be spinning at different frequencies so doesn’t that count for something? I’m sure that the top they were spinning in the video was under a regular lamp. Since the design has several levels that causes it to seem like its spinning all funky the Hz they “react” at will be different, so wouldn’t it work anyways?
Mine stayed on pretty well with no cracking. I just used standard spray paint and painters tape for the design, but I also messed up and made the paint way too thick. It looked good, but it was pretty heavy. I also only used the cover for a couple hundred miles of training/racing so I don’t know if that’s enough time to crack.
Nope – at least not that kind, that attempt to show any or part of the wheel spinning at different rates/stationary/backwards/etc.
Nope.
A “regular” incandescent lamp cycles at 120Hz. And the video was probably taken at 30 frames per second (30Hz).
No. Your eyes don’t work like video cameras – they don’t ‘sample’ at fixed intervals, it’s more like a continuous readout (albeit with some non-instantaneous ‘response time’).
I’ll repeat again just so it’s clear: You can get the weird effects under artificial light that flickers at some rate (street lamps, incandescent lamps, etc). AND/OR you can get the weird effects by sampling the images at some fixed rate. But you will not get the effects if you observe the wheel directly with your eyeballs under constant illumination (the sun, DC halogen lights, etc) or lights that flicker at high frequency – much higher than the effective ‘signal’ frequency of the pattern on the wheel (such as fluorescent lights with high frequency electronic ballasts).
