CULPRIT Enters the BTA (Between-The-Arms) Market
Originally published at: CULPRIT Enters the BTA (Between-The-Arms) Market - Slowtwitch News
Long gone are the days where, if you are serious about doing full-distance triathlons, you can rely solely on the nutrition on course. Even attempting that over the 70.3 distance is risky, in my opinion. And, thanks to our man Joe Skipper, who started the trend, if you don’t have some sort of bottle on the front end of your bike that makes you more aero and can carry some calories, you are simply doing it wrong.
So, with that in mind, the struggle is real when it comes to all the cockpit options on your bike these days. Getting something that is somewhat easy to adjust, lightweight and won’t break when you have two full bottles of liquid is a big challenge.
Joshua Colp of culpritbicycles.com is a long time forum user and a bit of a bike geek. The engineer, who lives in Taiwan with his family, has been working on this project for a while now.
The current offering is simple and well thought out. Like any engineer focused on a project, his company doesn’t have a skilled creative person, so the website needs some work, but all in all, it does the job.
Colp sent us what I would classify as the “total package” from his site right now – basically everything you can buy at the moment other than the full-arm aero bars.
With that. Let’s dive in.
Complete BTA SYSTEM:
  • Culprit BTA Riser
  • Bridge Tower Rail
  • Bottle Holder Rail
  • 2 Carbon cages
  • Computer mount
Bridge Tower Rail
The bridge for the tower comes in two styles of wings based on your needs. Both are well made, strong and easy to adjus, although picking the one you need can be a chore for a new athlete. To alleviate any issues, you will want to make sure you reach out and send photos of your current set up before you make your purchase.
Culprit BTA Riser
The BTA riser is well thought out and very easy to adjust once installed. (There is a trick you need to follow to get the under bolts installed.)
It has a height range of 101 mm to 146 mm in 9 mm increments, with five stops. It comes with 5° to 30° of adjustability, also in five stops. Everything is “lock in place,” so while you will be limited with the micro adjustments once the bolts are in, the unit isn’t going to slip. The height and degree adjustments even come with an extra third bolt to add extra protection. (Only two bolts are required.)
Carbon cages
The Carbon bottle cages are almost out of control tight, and I was a little worried at first. But I did discover that a “twist pull” on the bottle helps a lot. I have to be honest, though, I don’t know If I would use these cages on my bike as it really does take a good amount of effort to remove your bottle. The nice thing is that while you are going to have to get used the “twist pull,” you probably won’t ever have to deal with a rubber band to keep your bottle attached. Other than the snug fit, I didn’t have any issues with all three different size bottles I placed inside the cages.
Bottle Holder Rail
This is simple and basic – not anything that is out of the ordinary. There is plenty of adjustability for you to place bottles where you want them on both the top and bottom.
Computer mount
Carefully Integrated into the cage, the computer mount can even attach straight to the bottle rail holder if you just want a bottle underneath. I would like to see some extra bolts included with this, though.
Carbon Composite Speed Rests (CCSR)
These are a good, happy medium between a simple elbow pad and the full-on, custom arm pads/ cockpit flares we see used by some pros. At 210 mm long and 116 mm wide, they feel very compatible the forearm without creating the all-or-nothing feel of a full extension that covers your entire arm from elbow to wrist. There is plenty of adjustability, and the pads are compatible with M4, M5 and M6 bolts. There is plenty of padding, but I would like to see just a little more “stickiness” underneath the pads to hold them in place. (Or, at least an extra set – right now it seems little weak on the “glue.”) I also think Colp has some changes in mind and will eventually include some riser kits to enable some adjustable tilt.
Wrapping this up
Overall I think these are well thought out products that offer a lot of common sense adjustability and compatibility with other products on the market. The only thing I would probably suggest is to go to your local hardware store and change out some of the bolts with ones that are little more sturdy for long term use. Messing around with the system over and over again, the smaller bolts started to show some wear and tear. Also, for now, keep in mind that you will need to pay any sort of import and duty fees (which Colp clearly states on his website).
Colp sent these to us free of charge, and we were happy to give our honest feedback on the product. You can check these out at on his website at https://culpritbicycles.com.
weight?
I need to weight it.. give me until Monday. I should have done that but I failed you haha
Which item or do you want it all broken down?
Hi Nate,
comparing with Tririg. BTA riser, 2 bottle rail and 2 cages is the same as Tririg. However, my BTA bridge is different in that you m ay need to cut shorter as needed and it doesnt have extra sticking out such as Tri Rig and also adds more range adjustment with offset BTA to add/ reduce reach for a better bottle position.
BTA Riser 212 grams
Bridge 50 grams
BTA Under cup bridge 124 grams
BTA under dual stack bridge 118 grams
Complete BTA assembly with bridge, riser, 2 bottle rail, bolts. 410 grams. My cages are 60-65 grams each
Hope this helps
How does this compare to the tririg setup? Culprit had a little price advantage but not so much with tririg Black Friday sale and the stupid tariffs on the culprit.
Trying to decide which one to get.
Both products have their advantages. With TriRig hosting a black friday sale, the price is still a little higher than mine and mine includes free shipping globally. So, you can consider that. Also, whats easier/faster for you to get. I beleive Tririg has less total height and with Culprit you have the ability to shorten it further by cutting the inside sleeve. Different locking mechanisms with Tririg some micro adjustment and Culprit with fixed angle jumps. Either way your getting a reliable, strong alloy product and applaud you for choosing alloy products versus a 3d print.
I think the Culprit Computer mount on the cage is pretty cool. I think that it alone can really clean up the entire cockpit area.
Thought I’d chime in to this thread to say that I’ve just received some carbon composite speed threads from Culprit having only come across the company here. Couldn’t be happier with them.
They also made it into the EU (Denmark) where I live with no additional taxes.
Thank you for the positive words
Not having a go at all @culpritbicycles but the sooner these set ups are banned the better
They are mega ugly , and more so just make the bike handle like crap
Someone will be impaled with obvious serious injuries or worse
Just a accident waiting to happen, and then the law suits will flow either to IM and or the manufacturer
Just need to allow single bottles between arms. And not raised above the top of the arms
Would be very easy to write up and follow then the regulations
No offense here
Of course, if your running 3 bottlles up top, it really is to much. However, for many who ride narrow, 1 bottle isn’t able to install without any sort of riser. Also, without tilting then the bottle isnt flat and is pointed down. There is still a need.
I think it will come down to the rider’s preference and I just made an option that was 1. More robust, safer than what was on the market(3d printed stuff) which is safer for everyone , both the rider and those around the rider. 2. Cheaper than my competitors.
So, Yes, 1 bottle is good, 2 I think if done right is also ok and NOT a huge factor for me in steering thus far, but it is a personal preference and I respect your perspective on them.
