Guys, can I get some help setting up my CT please. I am currently using it as a stand alone because my laptop (Samsung V25) has only 2 USB ports and a 25 pin serial port for a printer. The problem occurs as CTs 3D program provides a 9 pin to stereo adaptor, and states in the paperwork not to use a printer port. Can anyone tell me how to get around this as I need to get some serious CT time in and wish to use spin scan etc. to get ready for IM Brazil in less than 6 months time
… I use a usb to serial port converter connection… if you read the sight it also notes that not ALL usb to serial port converter connections work (although most do). I ordered mine from CT and had not problem. The one sent was a Belkin - USB Parallel Printer Adapter (pretty generic adapter and driver).
Also, I might note that if you use a Palm top to download with your laptop, you could have problems getting the CT to recognize the port. For some reason Palm tops take over the available ports.
Joe Moya
I had the same problem - you just need to deactivate the “hot sync” feature on your pc/laptop before you connect CT with the computer.
Am I missing something here Rob? If I put the USB end into the USB port how do I connect the serial end (female) to the stereo cable to go in the handlebar mounted display unit? The stereo to serial adaptor supplied with the CT is female also!
Julian in England (getting more confused by the minute).
