Cryotherapy Unit: The new compression
http://www.wru.co.uk/eng/matchdaytv/index/index/id/10863
Where can I get one? ha
I have access locally to a cryo chamber. The main chamber is typically -205 F. It is unfuckingbeliavably cold. About the longest 3 minutes of your life when in there, but I swear it is an amazing recovery tool.
Saw this a while ago but with Alberto Salazar (http://www.youtube.com/watch?v=9hQsymsi5xU). If you want something a little less expensive - I’ve had really great results with 110% Play Harder’s gear - it kind of combines compression and cryo, but you can wear it under your normal clothes and walk around and live your life.
Little bit easier to use …
http://www.gameready.com/?gclid=CK761ZWP5a4CFcMQNAodVDH7xQ
Hi Rod,
Sorry to drag up an old thread, but is the Gameready product aimed at injury rehab or recovery like the Normatec (which doesn’t use ice water)
Same thing, really - recovery from hard efforts is a sorta’ micro injury!
But yes, designed more for recovery from a “true” injury though, but the same concept as all the other, later designs.
Thanks!
They don’t have the whole-leg boots, but I like the idea of the knee wrap. Was just wondering if you get enough “recovery” benefit without having your whole leg in a boot.
$2,300 for the control unit! Yowzers, I better keep studying…
