Did some searches on cross country skiing and decided to build it into my winter routine. A few questions
I have a fixed number of hours in a week, say 12. I would normally do 6 on the bike, 4 run, 2 swim. Would you take time from bike or run hours or 50/50 ? I am a bit weaker on the bike, but marginally.
If you skate, take it from your bike time.ex.do 3h of xc skiing, and 2h of cycling.if you do classic, you have to take time from your run and swim.
One smart workout if you want to work on your bike legs, try skating without poles.great leg workout, and it gives your arms a rest so you can still do quality swim training between skiing.
Would you say my HR profile will be closer to my run or bike profile ? Is there a LTHR test protocol for xcountry skiing ?
Closer to run, definitely.because you use your upper body as well, oxygen consumption is from time to time even bigger than running.xc skiiers have huge vo2 max readings.
Do people train by HR, pace ?
By HR, for sure.the effort required depends so much on the ski waxing, weather, meaning temperature, fresh/old/icy snow, hilly/flat course, etc.
Should I mimick a run plan (long, tempo, interval…) based on HR ?
Basically, yes. Actually xc skiing is different in the sense you can’t keep a steady HR all the time.if your HR on a long run is 140-145, expect it to peak to 160 skiing while ascending hills, then go down to 130 descending hills.avg HR is still about the same.
Any links to newbie training plans ?
I use Raceday which I like because it provides a TSS for all 3 sports and allows “other” sports. I can use a table from Friel to do HR to TSS approximation. Is this a reasonable way to come up with a TSS approximation ?
I am excited…bring on the snow.
