With all the latest information available about tire pressure, is this chart still usable?
This would of course be a base line to adjust based on surface condition.
No, generally those pressures are way too high. It will vary by wheel width, but to give you an idea, here’s ENVE’s recommendations for their wheels:
You also have to factor in rim width. This chart quite a while ago when most rims were 15-17mm internal. Now you have a lot of rims ranging from 18-21 internal which in turn means that the ideal pressure for each tire size could be even lower. I know HED plus sized rims are 21 mm internal and have a max pressure of 90 psi, even for a 23 mm tire.
The ENVE chart is better than most and if anything a bit low if riding on good pavement and a bit high for riding on poor quality surfaces…
The Michelin chart is way off and HED’s recommendation for 90max on their plus sized rims is based on tire blow off pressure and not on Crr considerations… which is true of all rim and tire max and min limits printed on the products or in the sales information, that is a calculated value based on a tested blowoff pressure which is required by law in the EU
We have lots of information on this including data and such at the SILCA blog: https://blog.silca.cc/page/5
Based on my reading, I thought those pressures were way too high. However, using the Enve chart I would be running 65 psi. That seems low.
I weigh in at 145 lbs. Closer to 140 on race day. I am running Zipp 808 carbon clinchers. Rear is a 2012 with aluminum brake surface (I’m still running it because my power tap is laced in it. Front is all carbon Firecrest 808. Continental GP5000 tires, 23. I still have to get real installed tire width. I wouldn’t have imagined running 65 psi.
Is there a later chart that would apply to my set up?
The bottom of this chart lists that these PSI recommendations are for a tubeless set up. I would imagine the recommendations would be lower for tubeless as the primary concern with lower pressure is pinch flats, but I guess I don’t know.
I wish I knew the magic number I should be riding at but the whole thing feels like a guessing game to me.
Those numbers seem REALLY low…
At 180 lbs, with 25mm tyres :
From Calvin386 table, I should put 102 psi
From Enve table (even if 17mm inner width, not 18/20) : 70 psi
From Silca test, on “coarse asphalt” : 90 to 95 psi
Is it me, or the Enve figures are really low, much lower than the Silca rec. ?
Does Silca have a chart or are you referring to their 5 part series?
Where are you seeing even with 17 inner width on enve chart?
I think enves are wider than most so you’ll see the lowest pressure rec with them.
For those questioning lower pressures, give it a shot. I am currently in the process of switching to disc brake wheels and have sold all of my hed +. Currently running the stock cannondale caad10 rims (which I’m guessing are narrow), and am running 60psi on 28mm tires. Haven’t pinched flatted in a couple months riding like that.
Edited to add I’m typically just over 160lbs.
Now I’m mainly doing that for comfort on training rides. I raced last season at 90psi on 20mm SuperSonics on hed + rims. I’ll have to do some experimenting on my new enves to figure out what pressure seems fastest on varying road surfaces (after I determine what tire/size seems like the best for them).
Yes refering to this :
https://silca.cc/blogs/journal/part-4b-rolling-resistance-and-impedance
The ENVE numbers would be fine if they were specific to a rough surface. Yes, the width of the ENVE rim tire well plays a factor in lower pressures, increasing volume in the tire and making it behave as a tire of larger width… the thing to remember though is that the tire doesn’t gain all the radial height that you would get from the wider tire… so while you can make a 25mm tire 28mm wide, your rim edge will be ~2mm closer to the ground that it would be on a 28mm tire on a slightly narrower rim…
Having said that, look at the charts in our blog, those are actual measured values on various surfaces and you can see that the difference in road surface roughness is a major factor. Similarly, rider system weight is a big player… so you can’t just go off of rider weight, but need rider+ bike… and also need weight distribution front/rear.
I typically tell people to pick a starting point and drop pressure from there, but if you are on the ENVE chart, I’d start there and go up a bit.
As an additional data point, I’m 175lbs and ride a 21lb steel road bike with 28mm Corsa G+ on 17.5mm inner width 303’s. Tires measure 30.1mm and my optimal setup is 66/68psi front rear while their chart would have me at 56-57psi… which is a fine pressure, but is well below optimal based on our testing on crappy Indiana roads… on nicer or newer roads the delta would be greater still as my optimal pressure would be greater than the 66/68
I’d suggest listening to our podcast to learn more here, but the real way to do this is to keep a log and test it for yourself on your riding surfaces. We do this with all of our pro teams and athletes and it is invaluable to keep that log so you can go somewhere new, and say ‘this looks similar to X’ and then you have a solid starting point for you, and your setup.
www.marginalgainspodcast.cc
My rims have inner width of 17mm
Enve chart have a column for 18/20.5mm (19.25mm average) width, the 70 psi comes from this column
Let’s suppose a 12% (19.25mm vs 17mm) larger rim give a 12% larger tyre.
According to RBR, this should remove 6 to 9 psi.
95psi - 9 psi = 86 psi
Not 70 psi
The Enve reco is really lower than the Silca, even with rim width correction.
Good for really bad roads ?
And/or for heavy casing training tyres ?
On really bad roads and with big strong training tyres, I could use the Enve rec (80 PSI with my rims)
With GP5000 on reasonnably good roads, I will stick with Silca rec (90/95 PSI with my rims)
Damn. I need to catch up with the times. I’ve been running 90psi @ 154lbs with Zipp Super9/808 and 23mm Conti GP TT, assuming average to good surface conditions. Probably not too far off for Roth last year but those roads are above average.
Yep I agree with all of this. If enve is correct that a 25mm tire is fastest on their rim I will almost certainly race about 80-85 psi I’d guess.
love the podcast—keep going deeper in your thoughts and discussions. Let that mind run loose with discussion
can you post what poor/average/good road surface looks like? I just sometimes wonder what definitions are used here. Even fresh laid asphalt looks different, sometimes quite substantially. What does grooved cement count as if we are riding with or against the grain?
Am I right in that they don’t mention the weight? Would it make sense, to mount the bike, and get someone else, to inflate the bike wile you are mounted?
https://silca.cc/...stance-and-impedance
No point the pressure wouldn’t change.
The only difference is the contact area of the tyre increases so that the area is proportional to the weight it’s supporting. Remember the tyre pressure is in pounds per square inch. So if you weigh 180 pounds, and the bike 20 pounds then the front and rear tyre area at 100PSI is 2 inch (so just under 1 square inch on the front and just over on the back). Get off the bike then the pressure is the same, but the contact area is much less (2/10 of a square inch). It’s the tyre shape that deforms and not the pressure that changes.
And of course the force on the ground is also 100 psi in both cases. Why a small lady in stilletos will sink into grass whilst an elephant wont.
However, if you use this excuse to get a servant to pump up your tyres for you, then fair play.
HED refers to the chart on their manual (page 7): https://www.hedcycling.com/Hed_TechManual_03082018.pdf
Of cause I dit not think of the pressure in that way. But if the deformation of the tyre is importen, how do I find my starting pressure. Is the deformation of 15% still a good starting point.
I once found this formula, and I think it is for calculating the pressure needed for 15% deformation?
PSI = 153.6*lbs/(tyre size in mm^1.5785)-7.1685
