The other reason I’m trusting his recommendation, is that a lot of research done in the past few year has proven many things with anecdotal evidence to be completely untrue. A few examples:
1)Many triathletes and runners love to wear hats(instead of visors) so they can fill the hat with ice at aid stations, put it back on, and have it cool their head. Science says-nope; not a big enough area to have a cooling effect on the body(it may feel good, but that’s about it)
I agree, visors are better than hats. That said, ice in a hat can have the beneficial effect of melting and dripping cold water over your neck and shirt in addition to cooling the head.
2)Many triathletes wear visors, believing that it helps with cooling. Science says-nope; the only difference between a visor and nothing is a little sun is kept off your face.
All I expect from my visor is to keep the sun off my face and keep sweat out of my eyes. I would like to see a commercial visor with neck cape to keep the sun off the back of my neck, though.
3)As mentioned earlier, arm coolers are another example. They may feel good, but they actually help keep heat in(better quality one’s do this to a lesser extent, but they still do it). The positive to these is that they go protect you from the sun though
The efficacy of arm coolers depends on the amount of solar gain, relative humidity, and availability of water. They’re much better in sunny dry environments,* than cloudy humid ones. They are also much more effective if kept wet.*
If you have any links to your prof’s work on the subject, please share. It sounds interesting.
Finally, what about my other bullets (1, 3, and 4) in post #6 do you not agree with?
