Got headed out a mile and a half on my training ride today and heard the dreaded “whoosh”. Felt air blowing on my left leg. I pulled over and inspected my rear tire where I could see a noticeable crack in the sidewall. Figured I hit something in the road that punctured it even though I didn’t see anything or feel anything happen.
I came home and stripped the tire off and took the tube out to patch it, but it wasn’t leaking air at all. Not sure what happened or if this is a common occurrence.
I bought the wheels and tires used so the gatorskins came with them. Maybe they had dry rotted or were past their prime. Luckily, this didn’t happen during my 40 mile ride Saturday morning!
One time helped someone where they had similar events.
They had lost pressure but when they went to fix it there was no leak and when they put the tube back in they couldn’t pump to pressure. Turned out thier brake pad was a bit high and cut the tyre wall. When the innertube bulged through a small bubble appeared, expanding and dropping pressure… And which made a whoosh sound each time it passed the brake pad, similar to the oscillating sound escaping air makes each time the hole passes. But in that case that is why the tire felt soft but didn’t have a hole.
How do you get a “whoosh” and the sensation of blowing air without air escaping from the tube? Are you saying the air supporting the tire was between the tire and tube? I’m not understanding that part.
I recently ran over broken glass and it cut the tire sidewall, but not the tube. The tube remained intact and fully inflated (but bulging through the hole in the tire) for another 175 miles – and still didn’t lose air then. If there wasn’t a hole in the tube, I don’t know how you had a flat.
Any input? Just curious mainly. Thanks!
If you bought them used and have little idea how old the tires and tubes are, I’d replace them.
If a tire has been left with an uninflated tube on a bike for a long time the sidewall will be damaged in the way you have described. Tires with stiff side walls like gatorskins will be particularly susceptible to cracking due improper storage. The damage isn’t always obvious when the tires are properly inflated as the rubber won’t have rotted or been worn through but it can’t be fixed either.
If I were you I would buy some new tires and write it off as the cost of buying used.
Check around the valve stem. I’ve had bad tubes that leaked there substantially, but intermittently. Toss the tube. If there’s a crack in your tire sidewall, toss it, too. You don’t need a high-speed blowout.
