Any recommendations for a bike computer that will work with a HED3? I currently have a Mavic Wintech. When I attach the magnet to the H3 spoke, it’s too far away from the sensor in the skewer to be picked up. So I’m looking for a different computer.
You just need to get a stronger magnet. Try rare earth. I just glued it on and it worked fine.
I use a Cateye, flat magnet from the hardware store and turn the sensor in alittle bit!!
You could use almost any computer with a H3 with creative use of epoxy and a rare earth magnet. However, if you are using a H3 on the front for aerodynamics, the sensor used with most computers probably is not that aerodynamic. Perhaps you should consider a bike computer with a rear wheel speed sensor.
I use Avocet 45tt computers with my Hed3 wheels. I have used them on the front wheel and on the rear wheel. No problems. Worked great.
