I am starting to wonder if it’s a good idea to wear these compression socks during road racing also. Would compression effect hurt or help me on the bike?
Dude… the test showed a 2:39 difference between a DeSoto LiftFoil and a DeSoto Forza suit over 40k. There has to be something off in his testing. He is not holding the same position or something. There is no way. (if they both fit properly)
They also say they found that CEP calf sleeves saved 73.8secs compared to 2XU calf sleeves which cost you 23.4secs! That’s 97.2secs between two different brand of calf sleeve…not convinced.
Part of the reason that I think there maybe some creditably behind this information is because there are papers showing that different types of textured fabric wrapped around a steel cylinder will produce a lower coefficient of drag over the smooth steel cylinder (around 40% in some studies). I may be assumed that the calfs are semi cylindrical objects in the wind so this may hold.
Take the results with a grain of salt as he never posted a follow up as he said he would.
The way I’ve seen this explained is that the rough texturing trips a turbulence layer leading to longer attached airflow similar to that of zipp dimples. This may work as it is very difficult for airflow to stay attached to cylinders.
It’s called a boundary layer and surface texture can control where it starts. I took fluid mechanics in college. I still don’t buy it. His position is changing.
This is exactly the advantage. Calves stay pretty vertical through the pedal stroke, and are much larger than the tubes on a bike.
