I did an OWS in a lake yesterday and got terrible calf cramps.
I’ve never had cramps like this before - but neither have I ever before swam in water as cold as yesterday - it was 51 degrees. Yes, I was wearing a full wetsuit (5mm) but it was still mighty chilly!
Was the cold water the cause of the cramps, or is that coincidental?
Two questions:
a) how can I avoid getting cramps like this?
b) if I do get them in a middle of my swim, what (if anything) can I do about it?
Thanks!
did you do a hard or long run in the 24 hrs previous? i find i can get cramps after a hard run session. solution, lots of salts is only thing i’ve heard that can help.
Probably not coincidental unless you can say that your calf muscles were as normally-relaxed as in the pool. If you were unconsciously pointing your toes more because of feeling cold… voila!
I swim in pretty cold water, but more like 53-56 in the winter and don’t suffer from cramps, so I don’t think it is the temperature specifically, however not to say that I never have gotten a cramp while swimming in open water. I think there a few reasons for the cramps.
- You are tense from the cold water and subsequently your calves begin to cramp. This also happens in the inner thigh, really painful.
- You are tight from previous workouts. Even though you are swimming, I think it is still wise to stretch the legs before hopping in. Especially, if you are duplicating an instance where you cramped before.
- You were dehydrated. A lot of times people do their swim workouts in the morning and are slightly dehydrated. The magic trick here is drink some water with 2 salt tabs about 15 to 20 minutes prior. Once you start to get comfortable with the cold water and OWS I don’t think you will need to do these things anymore, but they should help out.
Tridiego makes a good point here. Plus, cold water has a greater diuretic effect. Low blood sodium could have caused the cramps if you started slightly dehydrated and urinated a lot.
A precautionary note: Over-hydration (more than “some” fluid) just before OWS may contribute to shortness of breath.
