Mundane subject of the day: I’ve seen all kinds of recommendations about cleat position. Everything from 1st MTP joint over the pedal axle, to average of 1st & 5th MTP joint over the axle, to all the way back on the shoe slots, to mid-foot. At this point, my shoes demonstrate a variety of cleat position ideas.
Today, I’m changing cleats, so I thought I would ask what people are doing / recommending. Where do you have your cleats positioned? Does it work for you?
Since late July I’ve had my as slammed back as possible with my shoes, which as I understand it really isn’t that far because most shoes don’t accommodate too far back without modding. I think it took me probably a month to adjust to it though I didn’t think there was an adjustment period until I had some unexplained problems at Boulder 70.3 which was less than two weeks after I adjusted them back. A month after that at Santa Cruz and no issues at all. Feels better even. Ran better off the bike than I ever have (also some fitness gains though so not attributing everything to the cleats). If you’re heading into off season I’d slam back. Seems like most of the expert opinions are in favor of that and it’s realistically not going to hurt anything.
Slowman wrote an article many many moons ago (pre-Slowtwitch I believe) suggestion 1/3 of the way back on the shoe. I have ridden that way ever since and it has worked well.
I’ve always had trouble with a bone spur from an old broken toe, and proper cleat position (as recommended by my fitter) aggravated the hell out of it. So I slammed the cleat back all the way, and problem solved. To make things even, I did it on both sides. I had no idea I was way ahead of my time, as now it becoming the thing to do.
Middle of 1st. (traditional road placement). Briefly tried moving them to midfoot (speedplay adapter), but found my power wasn’t as good (didn’t give it much adaptation time though).
While I was recovering from Achilles issues, I started experimenting with mid-foot cleats. 1st with the Speedplay adjustment plate and now custom drill shoes for a true mid-foot placement. Changed to MTB style SPD pedals/cleats with the simpler 2 bolt pattern. Works great! Wish that I had done it years ago.
Here is an excellent article by a very smart man. Enjoy.
So, why then isn’t there a HUGE movement amongst triathletes toward a mid-foot cleat position?
I think there is a movement.
You have to watch for toe overlap with front wheel, but in most Tri’s you aren’t making too many turns and if you are they are low speed 180’s - so you aren’t needing to pedal through.
