Bought a Cervelo P2C Frameset and just found out from my lbs that the headset from FSA that fits it is long discontinued and they cant find a replacement. Bike will not be rideable otherwise!
Does anyone know where I can find one? I’m in Toronto.
P2C is the blue and black one .
edit: This is not a bearing problem → the frameset has no bearing
Ummm that doesn’t sound right at all. I don’t think there was anything special about that headset it was just a standard headset. It was the same in the p3, p4, etc if I remember correctly.
FSA May have discontinued their oem one but I’m sure cane creek or any of the other headset makers still have one that fits.
Edit: someone can verify this I don’t have those bikes anymore but i think it was the standard IS2 headset. There are about a million on ebay.
Why you taking it to MEC? I like MEC for a lot of stuff, and I buy plenty of cycling stuff from them but I wouldn’t consider them an LBS. At least not the MEC in Halifax.
Take it to one of the Cervelo dealers in the city, there are plenty of them
My P3C is a bit of a later model (2012 - last production run before the NP3 came out) but as far as I can tell it is bog standard IS2 stuff which you can get almost anywhere. Basically any 36 x 45 bearing set for a 1 1/8" steerer.
Most likely you just need to change the bearing which are very standard item. No reason for the other parts of the headset to wear out.
It is an integrated headset so there are not many parts on top of bearing. A cone and a dust cover. If you lose those 2 parts you can take them on any 1/8 headset and it will work.
I saw that frame on Kijiji. IIRC, the seller was taking ‘bids’ last week. What did you end up paying for it?
As others have said, this should be a relatively easy headset to figure out. All cervelo bikes (and many other brands) up to 2013 were using the same style headset, so there’s nothing unique or hard-to-source about this headset.
If you’re short on time, there are plenty of Cervelo dealers in T.O… Take it to Wheels on Bloor and they’ll fix you up in no time.
