For the sake of convenience I’ve started swimming in the community pool which is 25 yards and has semi-usable lane lines. I’m really struggling to find a good cheap pace clock. Basically, I just want a large battery powered digital clock that displays seconds. I’ve scoured Amazon and Wayfair to no avail but perhaps a fellow 'twitcher here has a recommendation.
Outdoors, I usually just set my watch on the edge of the pool. I bought a cheap battery (analog) travel clock and duct taped the back. I plan to try that this summer. I only need the second hand.
For the sake of convenience I’ve started swimming in the community pool which is 25 yards and has semi-usable lane lines. I’m really struggling to find a good cheap pace clock. Basically, I just want a large battery powered digital clock that displays seconds. I’ve scoured Amazon and Wayfair to no avail but perhaps a fellow 'twitcher here has a recommendation. P.S. I despise swimming with a watch.
I think this 10" wall clock from Cafe’ Press would work. It’s only $27.99 or $20.99 if you give them your email and get 25% off first purchase. I’ve thought about buying one of these myself, but then my pool upgraded their clock. Actually, it would make a cool wall clock also.
I just use my phone with a large-print timing app inside a plastic bag, then prop it up right next to the lane I’m swimming in. Not huge, but does the trick when needed.
Right?! It’s almost cheaper for me to buy a large-format off-brand android tablet and put it in a plastic bag than it is for me to buy a friggin digital clock of comparable size!
You can buy a Kindle Fire 7" with a waterproof case for under $100.
I’d go with that one or make my own with a $7 clock movement mechanism, a couple sheets of plexi and a printer.
I’ve thought about building one myself also. I have seen other homebuilt ones at pools made out of wood.
The issues are:
getting a movement that can handle the humidity
has the torque to spin large hands
finding large hands
building an enclosure that minimizes the water/moisture that gets to the movement.
Edited to add that Keifer does sell (replacement) movements for about $35.
I just replaced the movement on a wall clock (normal, not high torque movement) and didn’t have any issues with the torque for an 24" clock. I think even unprotected the movement would probably hold up for at least a year if it was only at the pool when you were.
