Any advice on changing the rear pads on a p5 would be appreciated. It’s not abundantly clear in the owners manual.
cheers
cheers
it pretty simple - i cahnged the drive side bolt from allen key to hex bolt now can change them without removing anything just … release the brakes and unscrew the shoes with the pads and change the pads screw the shoes pack onto the brakes…
when i change to carbon i also change placement of the washers to give more room
cheers. yes. a hex bolt would make it easier
try removing wheel and then u can “close the brakes” and remove the allen screw
you are a genius!!! or I not that smart. Let’s go with the former. great tip
