Champion System Tri Kit question
Looking for input on if the Champion System mens tri kits run true to size.
Thanks!
I got one through Triathlon Canada 2 years ago for Du-Worlds, so I’m not sure if anything has changes since then but my thoughts are as follows.
The shorts fit and feel great, I would say true to size for sure. The tops we got were a little tight I found. The race singlet was cut very tight, I got a large (which I wear in most other brands) and feel like I should have ordered an XL, the cycling jersey was closer to size but still a little small/tight.
I wonder though if the sizing/cuts vary from their top end “elite” or whatever stuff which Tri-Can made us get and some of the other lines…
Hopefully that helps a bit.
order a size up, they def run small
Yeah, they def run small on all there stuff. Now that i think about it… tyr is the only one i’ve ever rocked that fit true to size.
Honestly, if you can look at some other manufacturers. We went with Champ thinking they were the only manufactuer that we could afford with low prices and low minimums. Unfortunately there base clothing is EXTREMELY base. So you might want to look at the higher quality materials
This year we went with Pactimo, around the same price, and same minimums (a tad higher), but Quality, design, colors, and service, is night and day difference.
We order all our team kit for 10 guys off of the size charts, in various suit options, and rarely have to make any exchanges on any of the kit…so the charts must be fairly close
