Champ Sys "Summer" cycling jersey options
I’m considering ordering a Champion Systems “Summer” jersey to race a few crits this year. Here’s a link…
http://champ-sys.com/cycling/cycling-collection/cycling-jerseys/custom-short-sleeve-summer-jersey.html
It says it’s available with either raglan or set in sleeves. What does this mean? Which do I want?
It’s available in either race cut or club cut. I want the more form-fitting race cut. But what size for someone 6’2, 195lb? (I don’t have another jersey to measure against.)
Thanks.
Can’t help you on the size, but Raglan sleeves run down from the neck collar and across the shoulders, where the “set in” sleeves are more like what you would see with a typical t-shirt. IMO, the Raglan sleeves are much more comfortable and better designed. Club cut generally has more room for a gut and lovehandles, whereas the race cut is supposed to be more form fitting. HTH.
Also, fwiw, I’m 6’, 185 and would wear a Large with some room/stretch to spare in the Champion jerseys.
Thanks. Good info.
