Cervelo s5 with internal wiring. need help
Shimano Dura-Ace Di2 EW-7975-A-2 Internal Wiring Kit
Shimano Internal Wiring Kits
Short battery mount Features a 1010mm battery mount wire for battery placement under the saddle Internalizes all wires as well as the junction box with only the battery mounting externally Length of front wire segment from junction box to front of bicycle=950mm internal Length of battery wire segment from junction box to battery mount=1010 mm internal Length of front derailleur wire segment from junction box to derailleur=275 internal Length of rear derailleur wire segment from junction box to derailleur=720 internal Internal wiring kits are only intended for use with frames designed specifically to support Di2 internal wiring Internal wire kits are available in three degrees of internalization Internal wiring kits feature one of two types of battery mounts: long, which is the same mount that external wiring kits utilize, and short, which eliminates the water bottle cage mount allowing for alternative battery placement
which “degree of internalization” do i get? long or short battery mounts? i’m transplanting the non-internal di2 from my s3. both are size 54.
thanks!
Which do you want?
Internal wiring kits feature one of two types of battery mounts: long, which is the same mount that external wiring kits utilize, and short, which eliminates the water bottle cage mount allowing for alternative battery placement"It sounds like you have to decide if the battery goes into the frame or outside.
Styrrell
Pff, champagne problem.
You figured out how to make enough coin to buy fancy toys, but can’t figure out the owner’s manual? Fail.
Dang. Class Warrior Hater. There is no social contract in sports.
I wired my S5 and used the 7975 A1 kit. Also use Shimano base (y-7e098010) batt mount. It is a 20 minute job!
where did you purchase the 7975 A1 kit and battery mount? would this one work?
http://www.ebay.com/itm/Shimano-Dura-Ace-Di2-EW-7975-Internal-Wiring-Kit-/160651792771?pt=LH_DefaultDomain_0&hash=item256797d183
doesn’t specify the “A1.” not sure if that is crucial.
i hear ya. there’s always a couple of jealous dreamers out there that have to spout out his negative vibes to those with passion. he’s been stalking me in the classifieds…
The last two wire kits I got came from Starbike.com. They have it in stock and ship fast. You can use any 7975 rear wire kit but it will likely have the bottle cage battery mount that you will want to change to the Shimano base mount y7e098010. I let my LBS order it for me from Shimano.
would you mind posting some pics so that other s5/di2 owners can reference this? or you can ping me. so you sacrificed your rear bottle cage to hold the battery? not sure i wanna do that.
thx for your help.
Battery mounts under chain stay on left side! If you search, S5 build, on this forum there is a pic of my bike and you can see battery location.
Don’t flatter yourself. There exits a significant difference between “calling out” someone for their lack of technical skills despite their money making skills - and “stalking.” All the information you need to rig your rolling status symbol together is written in plain English in the owners manual.
single income household… makes WAAAAAAAAAAAAAAY less than the ‘standard’ triathlete.
i now rock Di2 on my Shiv… play your cards right
As single household income of 90k with access to pro deal hookups is still way less than the “average” triathlete. It is also “way more” than the average person has access to.
Unless you give me numbers and specific situation, your counterargument really isn’t one.
<$55k 4kids live in upstate NY with Taxes out my wazoo… no pro deal here…unless you are offering!
is that good enough?
did it ever occur to you that many on slowtwitch buy these bikes for performance and beauty? nahhhh, you’re too bitter living day-to-day. eking out a living, jealous of others who have the means… sorry otter, but being fat, dumb, stupid and poor is no way to go thru life…
oh and another thing. you don’t know me from adam, yet you have the audacity to judge? i would wager that i would smoke your ass any day on a tt course of your chosing…on my “rolling status symbol.”
(why am i arguing with a bitter, jealous troll?)
