Cervelo S3 size advice
I am in need of some bike size advice. None of my local fitters are taking appointments, yet. I bought a Cervelo S3 online without testing one first. The store recommended a 51 cm in the aero road bike, but then shipped a 48 cm in error.
Before I send it back, I’m seeking alternative opinions on size. I currently ride a 48 cm P2. I’m 61.75 inches tall with a 30 inch inseam. The salesman in my LBS said he would have recommended the 48 if he had one.
Assuming you’ve had a proper fit, do you have a picture of the bike setup to your number, and a list of said numbers?
I have only been properly fit to the P2. Here’s the data for the P2 if it is helpful in providing advice on the correct size of an S3 road bike. And here’s a link to a video showing the results of the P2 fit: https://www.youtube.com/watch?v=vsSHNZiqDrc
Stem: 10 degree, 80 mm
Spacer Stack: 35 mm
Crank: 165 mm
Frame Stack: 459 mm
Handlebar Stack: 556 mm
Frame Reach (BB to center of headtube top) 391 mm
Handlebar Reach (BB to center of bar) 431 mm
Handlebar Reach (tip of saddle to bar top) 442 mm
Arm pad reach (tip of saddle to back of arm pad) 383 mm
Arm pad reach (BB to back of pad) 372 mm
Grip reach (tip of saddle to front end of grip) 658 mm
BB to Grip Reach: 648 mm
Handlebar Stack:
Saddle Height (BB to center of saddle) 658
Saddle Setback: -10 mm
Arm Pad Stack BB: 591 mm
Saddle Angle: 0
Eff. Seat Tube Angle 78
Grip Angle 47
Can you do me a favor and take this to the Official Cervelo Fit Assistance thread?
I know it says TT bikes, but I can do road too :wink:
thanks,
Eric
Spacer Stack: 35 mm
Crank: 165 mm
Frame Stack: 459 mm
Handlebar Stack:
Saddle Angle: 0
Grip Angle 47
