It is not often that I change my mind about anything, as you all are certainly painfully aware of. Well, this is one of those times. I admit that it took me a while to get things set up the way that they are supposed to be set up. My initial ride was on a misfit bike with thrown together parts with out the right bars and on and on and on…
Well, today was my first ride on the real deal. I got the right bars on the bike – Profile Carbon X with special donated Titanium S-Bend extensions as opposed to the standard poorly designed extensions. The bike had a full Campagnolo Record 10 speed components that operated as well as one would expect from the premium group set from Italy. I today for some reason decided to take out the 909’s as well…call me a poser doing a training ride on race wheels if you will…but I wanted to know what the ride was really like. Total specs were the P3 frame, Profile BDC fork, Record group set, Carbon X w/Ti extensions, Time RSX Ti pedals, Vittoria Corsa CX Tubulars…53/42 and 11-23; 10 speed Record Ti cogset. Total bike weight of just a hair over 17lbs…certainly light for a tri bike.
I had not ridden the new extensions, nor any other S-Bend style extensions for that matter…I can say…boy do I like them. I often put no weight on my hands at all, and do not really pull back ever on the bars, they just seemed to be there for steering and to rest my hand on. Climbing hill’s I really don’t pull on them at all as I am a spinner and don’t force the climb. I had my bars today set 4.5 inched below the seat height (pad height). This put my back about parallel to the ground while on the pads…a bit less than 90 degrees elbow angle (that is just how I ride).
So…the ride. As you all know I look for bikes with “soul”. I can’t say at all that I found soul in the ride of the bike…however soul to me does not matter at 28mph. In the aero position I have to think hard of any other frame that would travel so fast, so easily. The acceleration was perfectly linear. I asked for more speed, I got it. The bike was in a hurry to move forward, and would take all that my legs had to offer. For years I have been on Softride frames…and if given an option it is a very hard call…the Softride frames had a bit of give to them, not bad per se, just that I felt that some of my energy was given up to comfort. Cervelo gives up nothing…and is not all that uncomfortable. Sure the Cervelo tells me that there is infact rough pavement, and yes there was a crack in that road…it is not harsh like Cannondales of the past, or the newer Scott CR1.
On the flats the bike just goes…again, no soul…just raw speed. Climbing the BB is as stiff as any out there, I was not able to call out any chain rub in the front Der (though these were not big hills, and I was not in a road race). Climbing the bike behaves as well as any, sure I can feel the added weight that any Tri bike carries…but not so bad at all. Descending…that is another story all together – the bike just goes. I took the bike up to 54mph on a down hill – no shimmy, no shake, no nothing, just speed. One of my litmus tests for a tri bike is to go no handed on it, I have ridden some that were not stable enough to ride hands free, and the P3 is not one of them. I was quite comfortable eating and sitting up at 20mph – I may be wrong, but the bikes that could not ride hands free on…were also spooky on descents. P3, I would not be afraid at all to take down the Keene hill at 60+ mph.
I was a bit concerned about the chain stays. I in the past I have ridden frames where the clearance from the chain stays to the tire was petty close and would rub the tire in a serious sprint or climbing tough hills. Again, nothing – though I had the tire about 3mm from the seat tube, and awful close to the chain stays (that are REALLY big when you look at them from above)…after the ride I even inspected the white paint on the stays…narry a mark from the tire.
I the end, I would have to say that my initial impression of the Cervelo P3 was an uninformed one. As has been said in the past, you cant judge a bike on a trip around the block…well, the same is true for a bike that is not setup properly. From the store, there is no Cervelo that will fit me right, and ride to my liking – then again, no bike will. Once I got the bike set up with gear that would fit my lanky long body…the P3 rode very well…no soul…just FAST.
