Cervelo p3 front brake reach
So it seems like my regular brakes don’t have a long enough reach on the front of the new p3 i’m building up. Does anyone know the necessary clearance you need in a brake so i can order correctly? Any experience with cervelo brand brakes?
thanks!
Mike
I think you’re either doing something wrong…or your previous front brake is non-standard with a shorter bolt than normal.
cervelo wolf fork, or cervelo ‘chord’ fork?
hmm, i got it used and am not sure how to tell the differnce. the seller called it “cervelo aero carbon fork”. it’s black carbon fiber with “Cervelo” written in white. does that help?
btw… it is from the 2003 model year
That sounds fishy. Best to contact our customer service and talk to them to figure out if it is a Wolf, Wolf TT or Chord. info@cervelo.com or 1-866-cervelo
I have the exact same issue with Record brakes and the BDC, the pads are as low on the caliper as they can get…and I am ok by about 1mm. This I know is an issue with Profile and Campy…not Cervelo.
it is a cervelo “chord” carbon fork. talk to the folks at cervelo…
