Cervelo P2K Geometry Question?
Has the geometry from the 2003 to 2005 Model changed at all?
Can anyone post a link of the 2003 specs?
Thanks.
From Gerard in a previous post: (in reference to the P2k vs. Dual)
No differences in ride quality or geometry between those frames that you or I can feel. That is if you are talking about the 2005 P2K. The 2004 had a slightly different geometry.
That must be a misunderstanding. Technically it has not changed, so the cutout is still the same, the internal cable routing, seatpost, etc. But we have gone to the sizing methodology of the Dual, which seems to work a bit better for most customers.
http://forum.slowtwitch.com/gforum.cgi?do=post_view_flat;post=285069;page=1;sb=post_latest_reply;so=ASC;mh=25;guest=2678439
AFAIK, the big differences are that the 650c wheels have been replaced with 700c in the 51 and 54 cm size. Also the 52cm 700c frame has been dropped all together. Any geometry changes would be minor and to accomodate the larger wheel sizes in the mentioned models.
link to 2003 webpage - which has the geometry: (hope it works)
2003: http://web.archive.org/web/20021126060746/http://cervelo.com/ (select P2k in the “tri bike” list on the upper left side)
2004: http://web.archive.org/web/20040214050908/www.cervelo.com/bikes/P2K.html
2005: http://www.cervelo.com/bikes/2005/P2K.html
(I wish Cervelo (and Felt) kept an archive of their old bikes online… like Cannondale, Bianchiusa.com, Trek, and Rooworld)
