My seat seems to be moving around when I ride. So rather than just keep trying to make tighter, anyone know what the torque spec is for the seat to post?
Thanks
Thanks
4nm
Make sure you grease the screws so they seat better
I have a 2012 P2 -Spec is 4 Nm Spec, I use a preset 5 Nm wrench. I have to us quite a bit of the carbon grip paste to keep mine from moving.
It is in your owner’s manual, as are all torque specs for bike.
I got no manual but what I find online for a cervelo manual says 12 Nm. Why so different than others posts?
Other people are confusing what you are asking.
gymrat and triing2run are giving you a different location than what you are asking about. 12nm is correct.
On my 2013 Cervelo P2 there is a collar at trailing edge of the seatpost with two screws.
The torque rating is printed on that collar (I am almost 100% sure it is 4nM… my bike is only a couple of months old, this may wear off eventually. If you want i can get a picture of this tonight)
I will tell you that if you over torque those bolts you WILL damage the delicate pointy edge of your seatpost and you will end up with a structurally compromised seatpost; the replacement will cost just over $200
You might want to check out this thread
There is the carbon seat post into the frame, and I believe this is 4 to 5 Nm. (And yes, do not want to break!!)
I am asking about the seat you sit on connected to one of the two holes in the carbon set post, which I read as 12 Nm, and you saying the same.
I am hearing about needing some carbon grease stuff to help it from moving also. Would you recommend it?
oops, i had misread your original post.
I was trying to help you avoid a problem i recently had. (I guess i forgot the “don’t ask me how i know” comment. For me luckily, the person that overtightened my seatpost corrected the issue and bought the replacement)
Ouch, this is why I am asking stuff. I have printed out a torque page from a user manual I found.
I have heard folks say that even some LBS will not torque unless the owner signs a release that if something happens, it is not the shops fault.
So, what happened in your case?
I know I have tightened to about 3 Nm but have yet to have the guts to try 4 or 5 since 3 feels so tight. I could take the bolts out and put some grease on that folks recommend but its holding so why mess with them.
But the seat to post is causing me issues. So 12 Nm is the spec. Just looking for the inputs on getting some carbon grease also.
I would rather be attacked with asking a dumb question than having to buy a new frame. ![]()
I had been afraid to take a wrench to my bike bike. It is my first carbon fiber bike and i don’t have a torque wrench.
At one point, someone who was working on the bike had over tightened the pinch tightener.
I didn’t notice anything at the time.
At one point while riding i hit an unexpectedly harsh bump.
What i didn’t realize at the time was that the compromised seatpost started gradually slipping (think outermost layers peeling like a banana)
There were a lot of clicks (which at the time i had though “first carbon bike… must be normal”)
Eventually, the seatpost was pulled for inspection and it was trashed.
Amazingly, i had planned on riding the Ironman Canada course a few days prior but a family emergency had postponed that trip. Otherwise i would have been hitting speeds of (verifies that my wife is not watching me type) 50 MPH on the downhills with a structurally compromised seatpost.
Wow, just the seat post and not the frame?
I broke down and bought a number of different torque wrenches. Better save than sorry.
Glad you found this before your race.
Carbon grease is a requirement, you only need a small squeeze packet. I use carbon grease on my P3, and use less than the max torque and my seat is very solid. On my original seat post, I took the bolts to max torque and after a year, the post was slightly crushed, hence for my new longer post, I do not go to max torque. Post has never slipped.
Larry
If there is no carbon, no carbon paste is necessary (i.e. on your saddle rails). GREASE, however, is a nice addition to any metal to metal contact and - especially - to bolt threads.
4nm
Is that total torque or above running torque? Is that dry or lubricated, and if lubricated is that threads only, head only, head and threads? If you find yourself asking “Huh?” To these questions then you will understand why 4nm could very well be arbitrary.
What’s the real answer for carbon bits? As high a friction as you can get on the faying surfaces and as low a torque as possible to the clamping force needed to generate that acceptable friction force.
James H is correct. I misread the OP, and was speaking of the seat post.
n = nano
N = NEwton
M = Mega
m = meter
torque is force x distance (length), so Nm.
nm = nanometer which is 1 / 1000,000,000th of a meter
