Hello all,
I’m interested in buying a P1 but I’m trying to make sure I get the right size. I suspect it’s either the 58 or the 61
I did a fit calculation at competitive cyclist and here are the measurements and the recommendations.
Measurements
Inseam: 83.5
Trunk: 67
Forearm: 38.25
Arm: 73
Thigh: 68
Lower Leg: 59
Sternal Notch: 150
Total Body Height: 183
The Aero Fit
Top Tube Range: 59.8 - 61.8
Stem Length Range: 8.0 - 10.0
Saddle-Bottom Bracket Position: 75.2
Saddle-Pedal Position: 92.4
Saddle-Ground Position: 100.2
Cranklength: 177.5
Aero Bar Size: L
Saddle-Aero Bar Pad Drop Minimal: 5.7
Saddle-Aero Bar Pad Drop Moderate: 11.0
Saddle-Aero Bar Pad Drop Intense: 13.2
Saddle-Aero Bar Pad Drop Maximal: 17.0
Pad-Ground Position Minimal: 94.5
Pad-Ground Position Moderate: 89.2
Pad-Ground Position Intense: 87.0
Pad-Ground Position Maximal: 83.2
The road bike I own now is a 58 but my fitter seemed to think it might be a little small. He said it was more the size of a 56 or so.
Looking at the rec’s it says the most important measurement is the top tube length. This rec 598 to 618mm.
If I look at the geometry of the P1 I get:
For forward seat position:
58 Top Tube = 560
61 Top Tube = 574
For Back seat position"
58 Top Tube = 589
61 Top Tube = 604
So the two ranges are 560-589 and 574-604
The recommendation states 598 - 618
Does this point to the 61 since the high end of the 58 doesn’t even reach the low end of my recommended top tube range?
Thanks for any help…
Jason
