A few days ago, I looked into the different options to upgrade my bike. After a bit research in the internet and also after a visit with a local bearing factory I would like to know about your experience with bearing upgrades. Before my visit and research with the factory I only new about the normal standard bearing in your bike and the ceramic upgrade. Well the marketing worked for sure, because I thought those are the only 2 different kind of bearings you could use in a bicycle.
However, after the owner of the bearing factory explained me, that instead of buying the really expensive ceramic bearings, I should look into the non-contact sealed (special low-friction seals), with a unique low-viscosity lubricant. I had the Shimano Dura Ace bottom bracket already with me and the difference between the DA bearings and the non-contact (no ceramic balls) sealed one was amazing. I took them with me to my local bike shop and everybody made huge eyes after I told them this bearings are not ceramic bearings. The mechanic’s in the shop thought I bought ceramic.
The research I did in the internet showed that you get about 4 free watt by the use of ceramic balls in your bearing, but I do believe you get the same out of this bearings as well without the huge price difference. I mean, all bearings are usually used in high turning machines and the ceramic once for extreme high turning. Well, even if you are super human you won’t make it for long with more than 200 RPM so I don’t think you will bring any of the bearings to the limit.
However, the start up torque penalty you pay with a normal bearing is “huge” compare to the non-contact seal which are designed for low torque applications.
So why still pay for a ceramic bearing? The non-contact seal bearings are made also in the size for your hubs. Same here, why upgrade to ceramic? Also the new Trent to the ceramic bearings in your headset? I don’t think it is worth the money like other athletes in this forum said in other posts.
The last thing what made me smile during my conversation with the owner of the bearing company was that he told me about a TEST done in Germany (I am from Germany) a few years back. He said that Porsche has the option to upgrade as well to ceramic bearings for an extra $5000…well the test showed that the ceramic bearings would only make sense once you reach the speed of 145 mph and up. Cool, so I don’t need that upgrade because I don’t know any place in Florida to drive that fast…lol
No, seriously what do you think about ceramic and how many of you heard about the non-contact sealed bearings with the special lubrication? Fact is, that I use them now in my Time Trial bike and the whole upgrade cost me less than $100. I went for a 100mile ride yesterday and I do believe there is a difference in the effort I have to put into my crank and the best part is that my wife still lets me sleep in the bed and not on the sofa because I didn’t spend again that much money for an upgrade. It took her a while to understand why I need a $6k bike plus the carbon rim set.
Thanks for your reply
