So I replaced the batteries in my Cateye Wireless and forgot what buttons I need push on both components to sync the two together. Can anyone help me out?
thanks
Jarred
thanks
Jarred
hey, if you just need to restart the computer, which you have to do if you changed the battery, just press the restart button on the back of the computer. all settings will be the same as before. if that doesn’t work then to reformat your computer, like you did when you first got it, press the menu and restart at the same time and release the restart. within five min of reformating the computer, press the reset on the sensor unit for five seconds… and then your computer should take you through the the complete formatting sequence. if this is confusing then download your manual from here http://www.cateye.com/en/manuals/66?PHPSESSID=1129525044549e31636e382ceeda665f
good luck
I think you may be asking about having to reset using the button on the back of the sending unit on your chainstay. That is a “press and hold for a few seconds”, but the manual is on-line if you go to the Cateye website.
