It’s easier for us to advise you if you provide height and weight, and if you prefer tight, medium or snugger fit.
I’m 6’0" 165 and wear M in Castelli team custom kit. I only wear the San Remo but I’ve tried on bibs and jerseys and would choose M in those too. That is with a relatively snug fit. Also guys that are similar in size but go L because they prefer a less snug fit.
We have guys shorter than me on the team that go L because they have larger upper bodies. Then again, we have another guy on the team who is also 6’0" and only a little lighter at about 155 and he went XS in a San Remo and jersey. But he has a narrow upper body and is an outlier as far as how he likes things to fit.
Have you tried asking your teammates? If they have experience with Castelli product and sizing, they should be able to help. I do this for new teammates often. Castelli also offers a Fit Kit that they can set up at a team night - you would have to check with your Castelli rep on that.
Finally, our club, which is based in Los Angeles, will be opening our fall kit order soon with Castelli and so the Fit Kit will be set up at our LBS sponsor from Sat, Oct 14 to Mon, Oct 16. So if you happen to be in the area you could try stuff on in person and know for sure.
I think it also depends on your preferred fit as well. Super tight? Comfy tight? Draggy and loose?
We’ve used Castelli for the last several years and the sizing has been consistent. I’m 6’3", 180lbs and wear large. Skinsuits (san remo and body paint) fit perfect. Jerseys are a bit loose in the zipper area when down in the drops. Otherwise all good fits.
Have an inch and 3-5 lbs on you, I wear medium shorts and small jersey in club cut, would probably get the same for aero cut, it’s snug but not uncomfortable in the slightest.
My road club uses Castelli. I agree it runs a bit on the small side especially compared to American companies so it is certainly possible you will not be in the same size. But, I have found Castelli’s sizing chart to be very accurate. In fact, I have been OK going with the smaller size if in between sizes.
Things could be skewed in the smaller sizes but I am 6’4" and I actually ended up wearing the same size jersey and bibs I wore when we used Voler. Castelli did fit a bit tighter but I was OK with that.
Our club got a try on kit so we were able to check things out.
My club is a cycling club with racers and non racers. The racers all like the Castelli kit choices and there have been essentially no complaints from them about sizing. Some of the more touring type people hated the Castelli fit and actually got the club to offer a second kit choice after 2 years. My hunch if if you are used to a “racy” fit you will be fine. If you like your cycling clothes to fit loose, probably not
I am also about 6ft 3in and 180-185 lbs and have never had a good experience with Castelli. I have been on two teams sponsored by Castelli and have gotten rid of every kit due to poor fit even after consulting directly with the Castelli rep and the charts. I have a 42 inch chest, 33 inch inseam and 33 inch waist. The tops are always baggy around the stomach and/or unbearably tight in the shoulders/arms (can barely get them through the sleeves). Then, despite my inseam not being all that long for my height, the bottoms are always barely to my mid-thigh which is too high for my liking.
Anyway, all my buddies love Castelli and swear by it, but I have yet to figure out the right size and am a few hundred in the hole for my efforts.
I’ve noticed this too… Overall I’d agree that Castelli fits smallish compared to US cuts, but in particular the tops are cut extra tight in the shoulders relative to the mid-torso (and I say that as a guy who doesn’t have big arms/shoulders). Picture the difference between 2 guys who are both 6-1 & 175, but the first guy looks like a surfwear model, vs the 2nd guy who really should be 6-1 / 160 except is toting around an extra 15lbs of middle-aged beer gut. The first guy would probably be a Large in Pearl Izumi but need to size up to XL in Castelli, while the second guy would probably be fine w/ the Lg Castelli.
I’m also 6’3 and around 185ish with a swimmer build.
I wear Medium bibs and Large jersey in the Aero Race. It fits tight, but my sizing is the same that I wear in Squadra.
Fit and quality is the best in my opinion. Hard to find the right fit when you are tall and fit with wider shoulders, and Castelli is as close as I have gotten to a perfect fit so far.
I have the 2016 San Reno, got a medium but had to size down to a small.
This year I got the SR in yellow/black and the small was a real small, thus needed a medium. Castillo moved manufacturing in late 2016 thus the difference I imagine.
Yeah, I’m 5’11", 180lbs, with the typical swimmer’s broad shoulders and muscular pecs. I couldn’t zip a large Castelli jersey past my sternum. Even in the extra large, it’s a very snug fit.
issue that isnt considered with charts is the fabric. some stretch so well and some never really do.
Pactimos chart compared to castellis would run smaller than castelli for small by a cm in all measurements
Castelli and Pactimo are essentially the same.
Medium
Chest 37.8 vs 38
Waist 33 vs 32
Hips 38.5 vs 38
Size charts denote “intention”.
Our fit models would be “Mediums” in our size chart. Thus when we’re fitting, we’re fitting to the hypothetical middle of that range. Therefore, our apparel ought to be able to also work for those slightly bigger and smaller than the fit model. (And yes, we have models for other sizes, not just medium).
Castelli tends to fit small compared to many other brands. Considering their size chart, this seams intentional as I’m a solid medium but find their fit more snug than other brands.
If you are fairly snug Medium in Brand A - You’ll be quite Snug in Castelli Medium. If that is OK, stay with the same size in each
If you are quite snug in Brand A - You’ll be incredible snug in Castelli, which means you’ll probably need to size up
If you are fairly snug in Brand A and want to be fairly snug in Castelli - Size up.
