Cassette question (11)
I’m running a FSA Gossamer Compact Crank (34/50 I think), and I’m looking to run a 9 speed on it.
Any idea what the correct/perfect cassette I should get?
Thanks!
11-23
I’m guessing you’re really good at using a search engine or have a similar crank
:stuck_out_tongue:
The correct cassette is the one that gives you the range of gears you need for the type of riding you do. That being said most folks run an 11-23 with compact cranks, since it will give a similar range as standard cranks with a 12-25, but with tighter spacing between the cogs.
