I recently purchased a 2019 Speedmax CF 7.0 and am curious if any other owners have seen a similar front brake fit issue that I have. The brake pads are set back into the fork and there is a groove in each fork leg to accommodate the pads as they open so as to not touch the fork. The issue that I have is the pads sit further back into the fork, beyond where the grooves stop (maybe 1cm). This results in the brakes not being able to open completely making removing the front wheel a challenge. Should I be concerned that the pads are always up against the fork, potentially rubbing off paint and maybe other damage?
